#41 |
Looking good Gabor. I wonder what you mean with Class D MosFet, I think the term Class D is referred to a switch mode amplifier.
miklos |
#42 |
HI
The mosfet is Lateral type . The company main product the class D amplifier was at the beginning . And now they call their mosfet Class D . But really nothing to do with Class D . You can find out more if you Google them or they even sell assembled kits on the forum . Here is some info http://classd.ltd.uk/home.php Greetings . |
#43 |
I see, the company called Class D manufacturing these devices ACD100NSD/ACD102PSD. How well the N and P channel devices are matched?
miklos |
#44 |
HI
I don't know , all I know after Renesans took over the manufacturing the Hitachi lateral mosfets I do not like them . I never tested yet . A have some 6 pair from Class D but I didn't did any test yet . Before I used EXICON those are one of the best lateral if not the best . I tested the Renesans in the ProFet , after I switch to Exicon heaven and earth the difference between them in favor of the Exicon . At the class D company they wrote me these are close to the quality of Exicon . I will see when I do some test . But I need to make a enclosure for the amp after I can do some tests . Greetings |
#45 |
The enclosure is the hardest part of the diy.
Here's one of mine, cost me ca. 250 bucks and a lot of elbow grease.
miklos |
#46 | |
I don't think about built this amp for now. I'am just curious. My problem with such amp is high idle current. With 2x50V, 400mA gives 40W - quite high. There is no any thermal feedback. Also good mosfet are not cheap - another small problem. But I cant stop thinking about this amp ...
Wojtek |
#47 |
HI
I need to correct you . These amplifier 100W/Chanel . 400mA /channel the Iq . So that not so much .Only a couple Watt in Class A . There are many amplifier give only 10W per side and biased in class A some of them close to 3A . |
#48 |
Hello
I forget also U can run the amp in Class A/B mode . These is a very high quality amp . But if you want something more simple take a look at the Zenquito .From the same designer . You can bias that in pure Class A or A/B to . Much simple less parts and great sound if U use similar components like many DIY-ers did in France .http://pagesperso-orange.fr/jm.plantefeve/theo.html You can open the site in English if you Google Zenquito DIY amplifier . Regards |
#49 |
Hi
I too amp very intrested in the performance of the Class D lateral mosfets They are made by Semefab. Semefab also make the Exicon and Magnatec Lateral Mosfets I came across the Semebab specifications for the acd100nsd and acd101ndd Mosfets and it is different to the spec published by Class D. You can find it here http://www.semefab.com.cn/acd100nsd.pdf http://www.semefab.com.cn/acd102psd.pdf |
#50 |
Hello, I am too interested in the GrandMos. I have a couple of Exicon pairs and I think I would like to use them in a simple topology like this one. I'd like to know if there are any stability issues with it and how well it performs.
Thanks in advance. |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 17th May 2005 12:58 AM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 02:50 AM |
| Page generated in 0.11602 seconds (81.37% PHP - 18.63% MySQL) with 11 queries |
