I want to build an amp with continous 150w and max 300 watt power, and +/-30v. I have some circuits for it. My problem is the power supply because I have a 400va transformer, but it isn't symmetric, so it has not center tapped secondaries. It has only one secondary, so i have to make a virtual ground . Could you give me a good, complete circuit between the secondary and the amp? |
#2 |
Account Disabled
Hi 842,
need more information - To drive what? Impedance? Transformer secondary voltage? 150W rms continuous and 300W rms max, is that right? Where does +/- 30V come in? Cheers, Greg |
#3 |
OK for 150 watt rms into 8 ohm you need 34 Vrms output. Do-able with a bridged amp running off +-30v.
For 300 watt rms you need 49 Vrms, or 69.3v peak, add 5v for losses, and make it 75 v rail in practice, for a bridged amp, or +- 37.5VDC, and that's assuming perfetc regulation, so your'e out of luck right out of the gate with +-30v. Into 4 ohm You'll make it IF the transformer regulation holds up for 300 wat peak. For 150 watt continious, you should be good into 4 ohm. All this assumes a brided amplifier......... Lukas |
#4 |
Ok.
I want to make an amp with 2 lm3886. (I know it is a chip amp, and not a solid state, but my problem is the psu) Here is my transformer: the front side, with the primaries the back, with the one usable secondary I created a little circuit to provide the 'virtual ground'. circ Is this circuit good? Will be Unequal Virtual Ground Splits a problem??? How can I solve this problem- if it is a problem?? |
#5 |
Your schematic for symmetrical supply (+ and - supply) is ok. It just needs double the storage capacitors for the same ripple as a full bridge set would.
However, your transformer seems less than perfect. It has a lot of secondaries, but I can't see any current rating for each secondary. If you have a 400 VA transformer, the rating is split across all these secondaries. You can't choose for yourself, which secondary you want 400 VA from. Based on the (little) available info, I don't have a good feeling about this project. sorry. Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good. |
#6 |
If you look at the data sheet for the LM3886 there is an example of how to use the chip with a single rail supply. This would be far better than a virtual earth arrangement. The catch is the need for a high quality, large capacitor in the speaker output.
#7 |
yes, i know this transformer is not the best, but I don't want to spend more money on this project so i will try it out.
There are 2 10,5V outputs on the transformator, with 3 and 0,5 amp rating. Maybe the 43V output can deliver 3 amp. And if it can, it is enough for the 2 lm3886 chips. I will double the capacitance of those caps. I'm afraid the output volts, the (+) and the (-) won't be equal (maybe it can be 2 to 5 volts difference). But tell me i'm not right. The original circuit That I modified has voltage regulator ic's on each rail. original circuit |
#8 |
I saw the single supply example on the datasheet.
But I read somewhere the single supply is not the best for this ic. Maybe it's a stupid question but I'm a newbie so i ask: Why do you think the single supply is better? |
#9 |
The PS schematic is essentially a voltage doubler, which will give you something like 2 x 60 Volts. This should blow the chip amps to pieces! If you want to use this particular transformer and these chips, single supply and bridging seems the way to go Regards, Dirk |
#10 |
Thank you for your reply.
I corrected the 2x60V mistake so it will be 2x30V with the circuits used below. Those 2 circuit below are use batteries, I change them to bridge rectifier. Here is the simplest circuit : simplest In this circuit the transistors are not appropriate, so i change them to 2n3055 and mj2955. maybe the better circuit Which circuit is better? Are these modified designs good?? if not , can somebody post me a virtual ground ps circuit? Are the voltages on the output equal? +30 :: -30 or something like this: -34 :: +26 ??? |
| Single power supply crosstalk? | lapoltba | Chip Amps | 7 | 22nd January 2007 07:32 AM |
| single Diode power supply? | robertc | Tubes / Valves | 8 | 9th November 2006 08:26 AM |
| power supply for my single ended amp | jhaible | Tubes / Valves | 23 | 2nd November 2006 08:51 AM |
| Page generated in 0.13977 seconds (72.13% PHP - 27.87% MySQL) with 11 queries |
