The following circuit appeared in the design ideas section of EDN:
![]() the description can be found here: http://a330.g.akamai.net/7/330/2540/...es/60905di.pdf |
#2 |
Q2 is not going to live very long...
#3 |
Insert a resistor in the base of Q2 to protect it.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
#4 |
Of course - my point was, it's rather strange for a specialised magazine to publish this not noticing such an obvious mistake, let alone in such a simple circuit.
#5 |
they do print corrections at EDN
#6 |
Account Disabled
I don't know why Q2 will be killed - I think Q1 has a better chance of getting killed.
The "flaw" in the design is that the voltage drop over Q1 is always Vbe of Q2, and if there is a lot of current going through Q1, it will get hold quickly. Also, the design would be a lot more interesting if it is done on N-channels. |
#7 |
Electrons are yellow and more is better!
Guys, I'll guess you don't have notice that this mosfet is connected backwards (we use this also at work) and the circuit may not need any gate resistors. This has to be determined from case to case.
/Per-Anders (my first name) or P-A as my friends call me |
#8 |
Therez no base current limit for Q1..in a practical circuit any short or overload will damage Q1 ......
SivanandBalan |
#9 |
You may have Vgs breakdown for the kind of voltage solid-state amp will see.
Q2 is fine. It should turn Q1 off fast enough before its base-emitter junction melts. |
#10 | |
Account Disabled
are you sure about that? |
| inrush current limiter circuit | Holger Barske | Elektor | 12 | 14th October 2006 10:34 PM |
| short-circuit protection in mosfet's amp...?? | csl113 | Solid State | 8 | 31st January 2005 06:10 PM |
| Page generated in 0.10069 seconds (73.34% PHP - 26.66% MySQL) with 11 queries |
