Old 12th June 2005, 08:21 PM   #11
Did it Himself
richie00boy's Avatar
Everybody's right
The LED must be a problem because no voltage is dropped across it. Therefore the current sink for the long tailed pair is not passing any current.
From the photo of the board you can see 3 3-pin devices hanging off board. I and Mattyo5 presume that these are your output transistors. You need an emitter resistor for each one. The amp may also have trouble driving that many transistors. If you are using that many transistors because you are driving a heavy load then I'm afraid sooner or later your tracks on your board will burn as they are not chunky enough.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 12th June 2005, 08:44 PM   #12
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Where and how?
And i've already done one with five to drive a sub and run without any prob...
Old 12th June 2005, 09:24 PM   #13
Did it Himself
Those tracks are just too thin for 500w. And only putting half of the transistors metal plate on to the heatsink isn't going to do it's life any favours.
I think you've been lucky so far with that...
Emitter resistors, i.e. in the emitter lead of the output transistors.
Old 12th June 2005, 09:36 PM   #14
Send a message via AIM to Mattyo5
try this...this links to the original p3 article explaining how to parallel transistors...rod doesn't really recommend it, but i think it can be done..
http://www.sound.westhost.com/project03.htm
look at FIG 2
i'm w/ richieboy on this one
-Matthew K. Olson
Old 12th June 2005, 11:09 PM   #15
jaycee is offline jaycee  United Kingdom
You aren't going to be able to get a CFP output stage running stable with that many transistors hanging off of one driver transistor. Especially not on blob board like that. You need 0.1 ohm resistors in the emitter of each output transistor, or they won't current share and one set of transistors will be doing most of the work while the rest do little. This is where the CFP output stage is a big failing, more than one output transistor is a nightmare.
I must also say the overall construction of that board looks rather poor. It's not surprising you've got problems. If you've got full negative rail on the output, check the connections to Q6, the arrangement of the bootstrap R9, R10 and C5. Also check the current sink formed by Q3, R7 and R8 - if it's not working, the LTP won't function. The LED should be lit.
Why so many transistors ? You're not going to get 500W output from that circuit. You'd need higher rails of 80V or so, which is going to toast the BC546 transistors, and also require a total redesign. If this is the output power you want, choose an amplifier design that caters for it.
Old 12th June 2005, 11:15 PM   #16
Account Disabled
Have you checked the input ground connection that juices up your LED current source?
I have done many multiple BJT output device CFP's and CFT's and always use Re's (emitter) to the rail to ensure sharing, then you can bring them all back through the single reference one to output.
Greg
Old 12th June 2005, 11:34 PM   #17
I guess I should say that I'm not a fan of the CFP output stage for anything more than one device pair. For more than that, I prefer the triple darlington.
Old 16th July 2005, 08:14 AM   #18
The P3A is a nice, simple, and effective design, but you need to redesign or make a different amp to start running huge power. There's simply not enough parts, and the BC546 transistors are not good for higher voltages. Also the P3A lacks resistors.
Here is a CFP amp with 5 pairs. You can look at this amp and get some ideas, and even you you have some ideas for me, I'm open to hear them. But I figured you can see how many extra parts I add to add to have 10 output transistors.
My amp uses 2SC2632 150V small signal for diff and current source, and used 350V MJE15034/35 for vas and drivers, and 350V MJL4281/4302 for outputs.
This is my own design, not a copy or clone of the P3A, but you may see some similarities. Don't be too confused by the dual VBE transistors, they are for sensing temp on 2 heatsinks. I used the Onsemi transistors because they are high quality transistors for cheap.
So far this amp has been tested and very stable up to +/- 52V but will be moving to +/-70V soon when I finish building. Goal is around 350-400W.
Thing I noticed a lot with CFP is you need some emitter resistors for the drivers and the bases, and it helps a lot with stability. Also, I'd recommend heatsinking your VAS and drivers, as my VAS gets warm with a heatsink, I'd hate to think how hot a naked transistor would be.
Also, your power transistors are halfway on the heatsink. The part hanging off gets hot too. I'd recommend getting the whole transistors on the heatsink, and putting them in the middle is even better than on the edge.
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 06:34 AM
CDM 2/29 Problem – HELP! Bassivus Digital Source 29 23rd December 2007 11:00 AM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 02:19 PM
GC amp problem Jamh Chip Amps 30 6th April 2004 03:50 PM
Page generated in 0.10901 seconds (79.22% PHP - 20.78% MySQL) with 11 queries
