Old 11th June 2005, 03:31 AM   #1
Send a message via AIM to Jasmeleg
Default Hooking up VU meter?
I have a meter out an old tape deck that was used as a vu meter. Well I scrapped the deck and kept the meter. I want to know if there is any way to hook it up to my current amp so that it will serv as a sound meter. I just want a visualation not a actual vu meter. Could I hook it up through the speaker outs and use somekind of transistor so is wont peak out when I turn it up past a point? Can I hook it up through the preamp with a regular transistor that will max when the amp is maxed? I have a fair amount of knowlage when it comes to electronics but with no formal training I dont know near as much as people on here do. For a 15 year old kid I know a whole lot about this stuff and want to become an electronic engineer and/or mechanical engineer so I want to learn as much stuff as I can. Can anybody point me in the right direction for books and/or web sites where I can learn this stuff? If you wanted to know this is going to be in an Allied 495 Reciever.
If you cant mod it right. Dont mod it at all.
Old 11th June 2005, 06:10 AM   #2
PRR is offline PRR  United States
PRR's Avatar
Probably not a real VU meter, unless you scrapped an Ampex. No matter, the cheap semi-VU meters are fun too.
First question: is it AC or DC? Put a 1K resistor in series, and then clip it across your speaker. Play soft, turn up slow. If it is AC, it will bounce-up with the music. If it is DC, it will sit at the left peg, quivering on bass notes.
If it is DC, add a rectifier. The simplest is to use any bridge rectifier, like you use in power supplies. 1Amp is more than plenty. 50V is OK up to very high powers, but 100V or more is a wise idea. The + and - bridge outputs go to the meter; the "AC" rectifier pins are the new AC inputs. Now try with the series resistor. If it wants to move left of the left pin, reverse the + and - connections. (Meter cases are often unmarked, and sometimes marked wrong.)
If AC (or DC plus the rectifier), fiddle the resistor so the needle slams the right peg when playing as loud as you ever need. 5K or 10K might be a good guess. Then you should have a nice bounce for most medium and loud levels. Getting a straight meter to read very low levels is actually very tough work.
A small refinement is to use Germanium diodes instead of Silicon rectifiers. Lower forward voltage drop, better twitch on low levels. Schottky rectifiers are also low-drop, though not as low as Germanium (at these low currents). The classic true-VU meter used copper-oxide, but you don't find these very often any more.
Old 11th June 2005, 07:05 AM   #3
If this solves anything I have hooked a led in parallel with a potentiometer before that on one of the poles and that worked but if I wasnt constanly ajusting the knob for the potentiometer I would end up overpowering the led. If I dont hook the led in I dont get a good bounce. This meter is out of an old sharp tape deck. It has 2 meters for left and right channle. Is there a way for me to have the circuit at a certain voltage with out manualy having to change the resistance?
Old 11th June 2005, 12:03 PM   #4
moamps is offline moamps  Croatia
Default Re: Hooking up VU meter?
Originally posted by Jasmeleg
....I have a meter out an old tape deck that was used as a vu meter. Well I scrapped the deck and kept the meter. I want to know if there is any way to hook it up to my current amp so that it will serv as a sound meter.....
http://sound.westhost.com/project55.htm
Old 11th June 2005, 02:36 PM   #5
mik is offline mik
Or you can try this..
http://www1.int.conrad.com/scripts/w...e=No+price%21#
Old 11th June 2005, 03:50 PM   #6
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Thanks for not judging...
I put a meter on my amp 'cause it looked cool (I guess the same reason manufacturers do it...)
So far I am planning to switch between voltage input, (the power supplies for ea. channel are separate and have a variac) temp of heatsinks, and now VU ish dancin' needles.
I have contacted Elliott in the past and after apologizing for my shallowness, I asked how to make a bad VU. He basically said what you did, but you were more clear. He also said the germanium diodes really help, and that if you are using a voltmeter without any built in resistor, use LOTs of resistance while experimenting, because the are quite fragile.
Old 11th June 2005, 05:53 PM   #7
Mr Evil is offline Mr Evil  United Kingdom
I have a VU meter circuit here. It's somewhat more complicated than the simple recifier approach, but the diode forward voltage is exactly compensated for, so it works even with very low input levels.
Since it's something pretty you want to look at, you might also be interested in the fading LED driver that is on the same page.
https://mrevil.asvachin.eu/
Old 11th June 2005, 06:50 PM   #8
diyAudio Editor
Variac's Avatar
Ooooooooo...led thingy
Old 11th June 2005, 08:04 PM   #9
cpemma is offline cpemma  United Kingdom
The LM3915/3916 bargraphs are well-suited to simple meters on the line output, as the basic 1.2V scale can be re-jigged to suit anything from around 0.4V to over 2V levels with a couple of trimpots.
They'll also take an AC audio signal without rectification -- the input to the buffer opamp has an internal (schottky?) diode fitted (anode to ground) so negative-going inputs are limited to the low drop.
You could do a similar trick with your analogue meter and use an opamp as buffer on the line signal so (a) volume adjustments don't affect the needle movement and (b) it provides a high impedance input to the meter so sound quality to the amp isn't affected.
Old 12th June 2005, 01:17 AM   #10
Account Disabled
Back in the 70's I used to contract design to an australian broadcast mixer manufacturer (all the ABC mixers,etc..) - they used REAL VU meters where the rise and fall and overshoot characteristics were rigorously specified.
Then along came all the amps featuring VU meters labelled for power output to fill a front panel. Then LED bargraphs. I saw value in that for the PA so included a 10 LED bargraph with top LED clipping indicator and the market loved it. In the '70's. Then any visual embellishment was considered a distraction from the music, at least for Hi End.
Everything old is new again.
Greg
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
Help hooking up a uP tobias_svensk Digital Source 0 15th May 2005 12:42 AM
Copyright ©1999-2013 diyAudio
