Diode on output? Diode on output? - Page 2 - diyAudio
Diode on output?
Diode on output?
Old 10th September 2002, 07:56 PM   #11
CryingDragon
Guest
Default Ummmm......
I can try it.
Old 10th September 2002, 08:01 PM   #12
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Diode on output
Originally posted by trwh
CryingDragon, here is an article that should answer your questions:
http://sound.westhost.com/vi.htm
I do not agree to the core of this article. The V/I limiter doesnot switch off the current, but softly limits it to a preset value. There is no voltage spike as a result. The spike could only occur if the current is abrubtly cut off, but that is not the case.
LaughingDragon, you can *measure * the speaker impedance by putting a defined DC current into it and then check the DC voltage with a comparator to a preset voltage. Only switch on the relay if the comparator says it's OK.
Jan Didden
Old 10th September 2002, 08:05 PM   #13
CryingDragon
Guest
Default Urmmmmm
Thanks.....Ummmm....Never benn called Laughing dragon before....
Old 10th September 2002, 08:06 PM   #14
jan.didden's Avatar
Default Diode
Well, we all must advance in life, mustn't we?
Jan Didden
Old 10th September 2002, 08:29 PM   #15
CryingDragon
Guest
Touche`
Old 10th September 2002, 09:07 PM   #16
PMA is offline PMA  Europe
PMA's Avatar
Diode on output?
Diode on output? Regardless horrible distortion it should also be avoided from following reason: when diode switches off (near zero) it will produce transient spikes at crossover speaker circuit.
Diode on output?Hide this!Advertise here!
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
diode vca - build and measured. what amplification for output signal? Domplotz Parts 10 22nd April 2007 02:45 AM
Laser diode output lands? buddha Digital Source 8 25th September 2005 02:56 PM
output diode bridge confusion Danko Power Supplies 4 17th August 2005 10:45 AM
Copyright ©1999-2017 diyAudio
