M250 Parts Replacement Querry.... - Page 4 - diyAudio
Old 17th June 2005, 06:45 PM   #31
ldanto is offline ldanto  United Kingdom
Send a message via MSN to ldanto
heinrich, whoever you are. are you the designer of the M250 at Makus M250
can you update the site or something? i really like the m250 and the mcd 1 and i really want the schematics for the mcd 1
Old 17th June 2005, 07:39 PM   #32
Send a message via AIM to Evileagle
marcus66 is the designer of the M250.
Old 17th June 2005, 09:25 PM   #33
thanks
Old 23rd June 2005, 02:12 AM   #34
I happen to have a handful of MJ15003, MJ15004. Can they be use here? What other changes have to be made when using 03/04.
Thanks for tip
Old 23rd June 2005, 09:41 AM   #35
AJT is offline AJT  Philippines
AJT's Avatar
Thanks for tip
i can not see why not! you can use them up to rails of +/-55volts, 4pairs is good.
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 24th June 2005, 05:23 PM   #36
Do I need to make any other change to use them?
Just straight substitution ?
Old 24th June 2005, 07:08 PM   #37
They should just drop straight in. They are slower in fT so there should be no stability problems. If you're running it heavy you might want to use 6 transistors per side instead of 4, but that's about it. You could always drop the rail voltages a little to say 50V or 42V if you want to stick with 4 pairs.
Old 21st January 2006, 04:51 PM   #38
Send a message via AIM to clovi_kate Send a message via MSN to clovi_kate Send a message via Yahoo to clovi_kate
Default hi to all
hi to all..
with regards to M250.. can i replace the output transistors with 2SA1302(pnp) and 2SC3281(npn)..and also the driver for C2344(npn) and A1011(pnp)..
tnx a lot...
ryan jan
Old 21st January 2006, 10:04 PM   #39
AJT's Avatar
Default Re: hi to all
Originally posted by clovi_kate
hi to all..
tnx a lot...
ryan jan
if you have them, use them, just beware of fakes!
Old 22nd January 2006, 02:26 AM   #40
djk is offline djk
djk's Avatar
" If you're running it heavy you might want to use 6 transistors per side instead of 4, but that's about it. You could always drop the rail voltages a little to say 50V or 42V if you want to stick with 4 pairs."
If they are real, four pair MJ15003/04 will have 2KW SOA at 50V. With 55V, a 38-0-38 1KVA transformer, and good heatsinking, they will do 500W into 2 ohms.
BOZ replacement parts Elkaid Pass Labs 33 31st October 2005 04:40 PM
Replacement Parts AR1 Analog Line Level 2 11th July 2005 02:52 PM
replacement parts robbie b Parts 1 7th February 2005 04:15 AM
Looking for replacement parts jschen Parts 2 1st June 2004 03:59 PM
replacement parts nak Parts 1 2nd December 2002 04:49 PM
Copyright 1999-2017 diyAudio
