4w All Fet Class-a Amp
Old 6th June 2005, 04:07 AM   #21
DarkHorse is offline DarkHorse  China
DarkHorse's Avatar
main section closer view,I didn't find R11(47ohm),so I replace it to 68ohm,and R14 is 1.5Kohm,gain about 23:
Old 6th June 2005, 04:09 AM   #22
DarkHorse's Avatar
the PCB,I cut the line wire using a knife,is a hard work!!!
Old 6th June 2005, 04:18 AM   #23
DarkHorse's Avatar
and using SEC's IRF510(second hand).
I will test it tonight,god bless me!
Old 6th June 2005, 07:57 AM   #24
UltimateX86 is offline UltimateX86  France
Originally posted by Ipanema
Hi Ultimate86,
Your circuit looks like a Le' Monstre variation. Have you build those?
Ipanema
I built a Zenquito, which is a kind of evolution with MOSFET of "Le Monstre"
http://www.bonavolta.ch/hobby/en/audio/monster.htm
l http://perso.wanadoo.fr/jm.plantefeve/home.htm
ProFet that I proposed has neither cascode nor driver !
Just Jfet input + Mosfet output ... but I do not have the complete diagram
Old 7th June 2005, 03:43 AM   #25
DarkHorse's Avatar
hi,all:
I test it last night.
it works abnormality ,that is to say---it doesn't works well,
result show it has about 0.5Hz surge,because first stage's low frequency gain is too strong,R3 should not connect to feedback loop,it's positive feedback...
so I decide to use other bias way(SK170's)...
look it's ac analysis graph:
Old 7th June 2005, 04:35 AM   #26
DarkHorse's Avatar
Take it easy!I will go on tonight,it has more suitable topology,and lower distortion...I believe it can sounds perfect!
the test in last night,I relocate R3(down end) connect to ground.
the surge problem removed,but the output point of first stage upto about 14V,no matter what,it sounds,and sounds pretty good,I can't hear any noise from the speaker,I only use one 10000uF/50V cap and shunted with one 10uF/100V MKP cap,
ouput stage's bias current is about 1A..
step by step,I walk to success...haha
this is updated version of schematic:
Old 7th June 2005, 05:48 AM   #27
padamiecki is offline padamiecki  Poland
cheers!
could you unconnect nfb and describe the sound after deconnecting?
regards, Pawel
Old 7th June 2005, 05:58 AM   #28
DarkHorse's Avatar
Originally posted by padamiecki
cheers!
hello, padamiecki :
nfb???
it's hard to say that now,but I will tell you tomorrow!
regards
WINCO
Old 7th June 2005, 05:44 PM   #29
http://www.selectronic.fr/upload/pro...nique/4180.pdf
Old 8th June 2005, 06:50 AM   #30
DarkHorse's Avatar
fail again!!!
the super low surge(0.5Hz) still existing!
I suppose it's open loop gain rate is too high,and the feedback is too deep,so it occur...isn't it???
last night,after the failed testing..I had to remove the Q4 and RP3,
replace with one resistor,the value is 1Kohm...it sounds:
the sound is so soften and sweet,put my ear close to the loud speaker,about 0.3 meter(1'),I only hear the heat noise of semiconductor device..no 50Hz low frequency noise---good!
sound quality is more than my ZEN2,I hear Michael Jackson's "billie jeans"...you can lisend it for a long time,didn't feel any uncomfortable and any noisily...
I will go on!
4w All Fet Class-a AmpHide this!Advertise here!
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 11:17 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Copyright ©1999-2017 diyAudio
