Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 7th June 2005, 08:09 AM   #41
AndrewT is offline AndrewT
W=I^2*R = V^2/R = I*V
If V is rms then W is rms equivalent.
If V is peak then W is peak = 2*Wrms when dealing with sine waves.
You use the version of the formula that you have values for. You don't need to do a current calculation in between if you don't have a value.
If the +Vrail is 24Vdc and you can swing to within 5V of either rail when loaded then the pk to pk swing is 24-(2*5)=14 and Vpk=7v.
Close to your 12.5Vpp quoted but not near 10.5Vpk=21Vpp.
10.5Vpp =5.25Vpk Wpk=Vpk^2/R =5.25*5.25/8 = 3.4Wpk = 1.7Wrms.
If you don't agree on any of this come back.
But please define your voltages, currents and power as either rms, pk or pp if there is risk of confusion to the reader.
regards Andrew T.
Old 8th June 2005, 01:12 AM   #42
Like I said, I should have clearified that I measure from peak to peak. And that's what i said in the second post:
And since I was measuring Peak to Peak, the amp stays within 5 volts of the positive rail and 5 volts of ground with about .66v input.
As for the swing, with the bias set at 12V at the sources of the Fets, the swing is from 6.75 v to 17.25 v. This is within 5v of positive and 5v of ground (IE, within: 5v to 19v).
I have to admit that it's post like this that make me refrain from posting at all. I was simply demonstrating a 'Simple AB amp', with my own interpretation of it.
Old 8th June 2005, 03:55 PM   #43
please keep posting useful info especially to beginners asking for guidance.
I reluctantly had to correct the error otherwise that newbie and any others reading the thread would be totally confused.
If you had avoided the watts conversion the whole problem would have gone away and the relevance of your post would have been just as good.
regards Andrew T.
Thread Tools
ISO "Simplest" possible amplifier dano12 Solid State 32 27th February 2009 11:07 PM
Simplest class D ever Rikard Nilsson Class D 3 9th November 2008 08:09 PM
simplest amplifier possible with BJT's? rmgvs Solid State 123 10th July 2008 04:05 AM
LM3886 GC - "Simplest Ever Amplifier Bridging" jweber Chip Amps 20 18th June 2006 03:55 AM
Page generated in 0.16708207 seconds (68.90% PHP - 31.10% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
