amplifier circuits - diyAudio
Old 28th May 2005, 03:37 PM   #1
madan is offline madan  India
Send a message via AIM to madan Send a message via MSN to madan Send a message via Yahoo to madan
Default amplifier circuits
Hello,
I newer to this forum .Recently I'm trying to build an Amplifier .For this I have taken a circuit from http://sound.westhost.com/project27b.htm .But the thing is the PNP Transistor (Numbered BD140) which is connected to the MJ3055 is getting heat within few minutes whenever switch on the circuit.I can't find out the problem and proceed forward.So pls help me to complete the amplifier.Here I'm using the Power supply +/_30 volts railing.
Best regards
Madhu
Old 29th May 2005, 02:17 AM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Madhu,
Check the connections to the 2N3055's are correct. Bring the amp up slowly and watch the bias current.
-Chris
Old 29th May 2005, 08:26 AM   #3
Workhorse's Avatar
Honey,
Have connected the BD140 and BD139 on the heatsinks , since these are CFB forming pairs, their temperature compensation must be adequately implemented..... apart from that is your connections are wired right , check the connections and proceed further.....
Old 30th May 2005, 02:17 PM   #4
Default Amplifier Circuit
Cris,
thanks for your sugession.I don't know how to measure the BIAS CURRENT .Rest of this every thing ok on my circuit.So please let me know how to measure the bias current .
Best regards
Madhu.
Old 30th May 2005, 02:56 PM   #5
edl is offline edl  Hungary
edl's Avatar
About measuring the bias current:
there are 1ohm rated power resistors between the collectors of the output devices and the output of the amplifier.
let's measure the DC voltage on these resistors.
you know, I=U/R
so, for example, if the voltage is 100mV-DC, then the current is: Ibias=0,05V/1ohm, so 0,05A=50mV
Old 31st May 2005, 10:33 PM   #6
anatech's Avatar
Hi Madhu,
Yes, edl is correct. Let us know.
-Chris
Old 1st June 2005, 08:14 AM   #7
Hi All,
I'm trying to measure the bias current and ect...I'll come back you soon.
Madhu.
Old 12th June 2005, 08:16 PM   #8
Hi all
I went through that and measured the bias voltage across the resistor(collector to the out put ) is zero.And I observed that in the circuit Veb of the out put -NPN transistor (2N3055)as 10.2 Voltage.But the Vbe of the -PNP transistor(MJ2955) is 0.7 votage.Please let me know what might be the problem.
with regards
Madhu
Old 12th June 2005, 08:44 PM   #9
anatech's Avatar
Hi Madhu,
Measure across the 0R1 resistors in the emitter lead. It sounds like the E-B connections are reversed biased (or open - ouch). The 220R resistor may be open, also the 0R1 resistors.
-Chris
Old 12th June 2005, 09:07 PM   #10
Hi anatech,
Ok I measurd the voltage as 0.2 voits.Tha resistor(220 ohms) working well .You said that"may be E_B reverse biased".If it is right what about complimentary transistor.I hope you will clarify my doubt.
Amplifier and speaker protection circuits Peter Daniel Pass Labs 140 18th February 2012 11:14 PM
Looking for condenser microphone amplifier circuits pebo Solid State 3 4th September 2008 12:00 AM
Opinions from amplifier analysers on these amp circuits georgehifi Solid State 10 11th April 2007 03:56 AM
classic amplifier circuits/designers lt cdr data Solid State 5 27th December 2005 11:24 PM
Copyright 1999-2017 diyAudio
