AD 846 AN is ther a better sounding opamp out there - Page 2 - diyAudio
Old 23rd September 2002, 07:56 AM   #11
AD825 is not available in other than surface mounts. This may influence your decision as you might need a converter.
Petter
Old 27th September 2002, 08:33 PM   #12
ALW is offline ALW  United Kingdom
Default Re: AD825
I've used these a lot, in all manner of applications.
They do sound unusually good for an op-amp, and at least one of the reasons for this is the unusually high open-loop bandwidth, something almost unique in voltage feedback op-amps.
The only VF device I currently prefer over the AD825 is the AD8610.
A.
Old 27th September 2002, 08:42 PM   #13
Banned
Question unusually high open-loop bandwidth?
Do you mean the unusally low open loop gain? There are many higher bandwidth op amps.
H.H.
Old 29th September 2002, 01:09 AM   #14
ppl is offline ppl  United States
ppl's Avatar
I would not Recomend the AD-825 be used ahead of the BUF-634. Both the AD-825 & the BUF-634 have High DC offset and this offset is in the same Direction resulting in an overall High DC offset of about 20Mv used in Typical Closed Loop gains of 20 dB. On the Otherhand the OPA-627 & the AD-8610 Result in an Overall DC offset of Less than 1Mv. The Bandwidth of the AD-825 is also Large and Evean with the BUF-634 operated in it's wideband mode will require a large Phase lead Cap around the Opamp of about 30 pF for stability. Moreover Sonicaly the AD-825 & BUF 634 do not blend well together. I would sugest the AD-8610 as this Opamp IMHO sounds Better than the OPA-627. The AD-8610 has the Smoothness of the OPA-627 but without the Distent Midrange of the OPA-627. Both the OPA-627 & the AD-8610 Sonicaly blend well with the BUF-634.
Old 29th September 2002, 05:16 AM   #15
G is offline G  United States
G's Avatar
You might also check out the AD797. Impressive specs.
G
Gavin
Old 29th September 2002, 09:11 AM   #16
Default Harry
Well I guess one comes with the other, all things being equal. I did mean what I said though, most op-amps copensation schemes roll off OL BW at a very low corner frequency, the AD825 corner is 8-10k.
This is unusual, unless I've missed some devices - it's never part of a parametric search, making it time consuming to investigate.
IMHO wide open loop bandwidth, flat over the range of frequencies being amplified, is important for audio and almost all op-amps fail in this regard.
The conventional OL BW of 99% of VF opamps tends to introduce frequency depedant, non-linear phase responses in the amplifier as a whole, due to input stage transconductance non-linearities, worse with BJT inputs, so the AD797 mentioned above is not good in this regard, depite the impressive looking data sheet.
As always though, there's much more to it than this.
A.
Old 29th September 2002, 09:22 AM   #17
ppl's Avatar
Yes this is one nice quality of the ad-825 that 10KHz. rolloff. Some other Opamps used for Video applications whitch is also the case for the AD-825 also have high Rolloff points and Low open loop gains, However most use BJT as input transistors and then input Bias curent becomes an issue with reasonable source resistences. I would like to sugest the use of an opamp Buffer Combo as an alternative to get constant amount of overall feedback over as wide of a range as you want See walt jungs Multiloop feedback Idea http://www.elecdesign.com/1998/dec0198/tt/1201tt.shtml
Old 29th September 2002, 10:30 AM   #18
jcarr is offline jcarr  United States
ALW:
>the AD797 mentioned above is not good in this regard, depite the impressive looking data sheet.<
My view is that the quirks of the AD797 have more to do with how the current-mirror is handled and comparatively less to do with the input stage treatment.
Topology-wise, the interesting aspect of the AD797 is the bootstrapping of the current-mirror. What this kind of topology typically accomplishes is a substantial but conditional increase in open-loop gain. Compared to what you would get without the bootstrapping, the OL gain at low frequencies keeps on increasing and increasing, but the roll-off slope in the upper frequencies largely does not change. Ergo, when you set a given closed-loop gain, you get a huge increase in the amount of loop feedback at the frequencies where the OL gain is available and a corresponding decreasing in distortion - but the benefits are definitely frequency-dependent.
So in the end, I would largely agree with your final assessment.
regards, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 20th April 2004, 10:45 AM   #19
thanks evey one for your help i tried the AD 627 AN could not find the opa 627 works great has any one tried this opamp thanks again
Best sounding DIY SS amp trespasser_guy Solid State 73 24th April 2014 04:09 AM
What is better sounding I/V con. ? Gasho Digital Source 25 29th September 2010 06:21 PM
Ther humble LED jmateus Everything Else 2 10th December 2007 02:34 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Copyright 1999-2017 diyAudio
