my amp
my amp
Old 27th May 2005, 02:31 AM   #1
tlf9999 is offline tlf9999  United States
Account Disabled
Default my amp
I built this amp based on a N-channel quasi I did a very years ago, and then married it to the JLH front end.
Sonically it is very nice, and handles capacitive loads at ease (notice the 2uf cap on the output terminal), because of the current feedback.
You can also run the traditional differential front end but need to use a higher miller cap (C8). I have fond that the design is quite insensitive to the choice of transistors and if you adjust R13, R14, and R15, you can also use bipolars as well.
Old 27th May 2005, 02:47 AM   #2
Account Disabled
here is the 20khz driven into a 4ohm/2uf load network.
Old 27th May 2005, 02:49 AM   #3
Account Disabled
schematic
Old 27th May 2005, 04:35 AM   #4
Samuel Jayaraj is offline Samuel Jayaraj  India
Very good stability into a capacitive load.
Despite using dual rails, why is C3 (3300uF) required at the output?
Sam
Old 27th May 2005, 04:56 AM   #5
amplifierguru is offline amplifierguru
Account Disabled
Hi tlf9999,
why not bias your input base from ground directly and run a variable resistor from the =ve supply to the feedback C at the emitter and adjust for DC offset. A little simpler.
samuel Jayaraj,
You're right - there's no need for the output C of3M3F, but I'll be damned if I can see how you evaluate stability on 20KHz sine - and in the dark as well! My hat's off to you.
Old 27th May 2005, 10:41 AM   #6
but I'll be damned if I can see how you evaluate stability on 20KHz sine (posted by amplifierguru)
I understand that it should have been a square wave test but there are too many amplifiers that will begin to oscillate even when passively connected to such a large reactive load, let alone being tested dynamically. Isn't the 'normal' output inductor there only to combat such capacitive loads? And how many of these (commercial) amps can safely be terminated with high capacitance cables, more so without the output inductor?
Sam
Old 27th May 2005, 11:11 AM   #7
Account Disabled
because the simulation was done with 0vdc negative rail.
I wouldn't run this on +/- rails without a DC servo. The DC offset does wonder more than if differential pairs are used on the front: about 30-40mv, similar to pretty much all current feedback amps I have used.
Old 28th May 2005, 08:34 AM   #8
Although Output Offset Voltage close to zero volts is desirable, upto 100mV should not normally be a problem. Remove the output cap and please report back.
Sam
Old 28th May 2005, 11:10 AM   #9
Account Disabled
it runs no problem without the cap.
here is the fft running 100Khz sine input and driving into a 4ohm/2p network, at about 90ma bias and 56v rails, without the output cap.
it is mostly low-order harmonics (<7x), at about 0.4v.
Old 29th May 2005, 12:23 AM   #10
Account Disabled
I also ran a version on NPN output devices (mjl21193 ?), with minor changes (driver resistors) to the original circuitry.
my ampHide this!Advertise here!
