The many faces of distortion
Old 30th June 2005, 01:55 AM   #191
andy_c is offline andy_c  United States
Banned
A while back in this thread, there was discussion about power amp output transistor models. I came up with a model for the MJL3281a that was a tweaked version of the OnSemi model, modified so its DC parameters were a much better fit to the data sheet characteristic curves than the standard one. I cloned this model to a PNP as well, making a symettric pair. I put these in the simulated circuit below, with a stepped DC current source as the load, going from -20 A to +20 A. This circuit has 0.22 Ohm emitter resistors, with the bias current adjusted to Self's optimum value for this configuration, 107 mA per device.
I plotted V vs I, which wasn't very interesting. But there's also the undocumented LTSpice d() plot function, which takes the derivative and plots it. This is more interesting, as it gives the output impedance at DC as a function of load current. In reality, this could be a multi-dimensional nonlinearity - that is, the output impedance could be a function of both output current and voltage, but I'll neglect that for now. Also, it would be more realistic to have a non-zero resistor from the junction of the two bias voltage sources to ground. A picture of the test simulation circuit is below.
Old 30th June 2005, 02:02 AM   #192
Banned
The output impedance vs current is shown in the graph below.
One interesting thing might be to try to duplicate this behavior as a nonlinear one-port using controlled sources that are polynomials. This might be done using MathCad or a similar tool to fit the I/V curve. Then, this nonlinear impedance could be put in series with an ideal, distortionless voltage source. Any computed distortion would then be due only to the impedance nonlinearity and its interaction with the load. The effects of feedback on this distortion could also be examined.
Old 30th June 2005, 02:14 AM   #193
Jorge is offline Jorge  Brazil
Default Andy C
Very interesting.
And it holds for different Iq values?
Thanks,
Old 30th June 2005, 02:43 AM   #194
Banned
Here it is with quiescent currents of 50 mA, 107 mA and 150 mA. Lowest impedance is highest current of course.
Old 30th June 2005, 02:54 AM   #195
Looks like it's due to gm overlap of the output transistors in class AB.
If so, very little can be done with classical topologies.
Old 30th June 2005, 03:05 AM   #196
Banned
It does seem to reinforce the concept of optimum bias though. Look at the ratio of max to min Z in the low-to-medium current region. The middle curve is clearly best.
Old 30th June 2005, 03:46 AM   #197
amplifierguru is offline amplifierguru
Account Disabled
Hi Andy,
Haven't you been having fun???
Want to do the same for a MOSFET (IRFP240/9240) output and different configs?
Greg
Old 30th June 2005, 04:04 AM   #198
Banned
Doesn't CircuitMaker do that? Seriously though, I could be talked into that if you're really interested in looking at it. There will be some asymmetry I'm sure, as well as some minor DC offsets.
Old 30th June 2005, 04:33 AM   #199
Account Disabled
Well,er.. no it doesn't. Not last time I looked.
Yes please. If it's no trouble?
Greg
Old 30th June 2005, 04:39 AM   #200
Banned
Okay. What kind of configurations were you looking for? Variables might be:
1) Number of parallel output devices?
2) Source resistor value(s)?
3) Quiescent currents?
4) Others?
The many faces of distortionHide this!Advertise here!
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
distortion of SW CAD III SkyChu Solid State 6 19th June 2004 08:11 AM
Fresh Faces on the moderator team planet10 Introductions 18 24th December 2002 02:53 PM
Copyright ©1999-2017 diyAudio
