Old 21st June 2005, 07:03 AM   #11
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Grey,
I'm not making a line driver here. I'm applying this for a preamp, with no "long" cable. It is in openloop mode, no feedback, and how many voltage gain I wanted depends only the 1 final resistor value. The bigger resistor I put in the final, the bigger voltage gain I get in openloop mode.
Old 21st June 2005, 04:08 PM   #12
PMA is offline PMA  Europe
PMA's Avatar
Originally posted by GRollins
With current-driven connections vs. voltage-driven ones all you accomplish is to exchange series and parallel R, C, and L. They still matter, just in a different configuration.
Yes, from the first point of view. My objective result is that I have completely cancelled all of the RF and HF D/A residual stuff, that has been present with voltage drive.
Old 23rd June 2005, 03:46 AM   #13
lumanauw's Avatar
Voltage in, current out, no feedback. I just realize NP is (has) doing this as power amplifier in F2 amps, while I just think of it as preamp
What should be the optimim level of Input Signal to a LM3886 based amplifier kuldeepsingh Chip Amps 9 14th May 2008 10:17 PM
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
Can amplification based ta3020 amplify direct current signal? green3002 Class D 0 14th October 2004 06:01 AM
Want to check and verify that I am getting best possible digital signal transfer??? PaulHilgeman Digital Source 10 7th July 2003 05:34 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
