About my hybrid nofeedback AMP
Old 7th June 2005, 08:24 AM   #21
Graham Maynard is offline Graham Maynard  United Kingdom
R.I.P.
Graham Maynard's Avatar
Hi CK
Without C42-45 the four triodes should still not start to roll off at about 25kHz, so are you using a low impedance source with a high quality input coaxial lead ?
For high fidelity it is *essential* that your source has a low output impedance to drive against feeder cable and amplifier input capacitance.
I have graphed the response of four possible source/cable responses.
Yellow; 100 ohm source plus two metres of miniature single core into 100k.
Aqua; 1k ohm source plus two metres of miniature single core into 100k.
Fuschia; 1k ohm source plus two metres of premium audio cable into 100k.
Silver; 10k ohm source plus two metres of miniature single core into 100k.
Could this be where your 40 degrees of roll-off is coming from ?
Cheers ......... Graham.
Old 7th June 2005, 05:29 PM   #22
ckwong99 is offline ckwong99  Hong Kong
Seems the silver cure with a huge roll off. In my case I only connect the signal generator output direct to the AMP input. The signal generator is a general one (kit product) about 300HKD.
Nevertheless, it connect to my Matissa DIY Pre-AMP (such PCB made in China) would not happen this sympton. It can generate a very good output w/o phase shift even up to 20KHz square wave input.
Perhaps, the input stage PCB design and etchant by myshelf. Which is double layer supply associate with the gain circuit. PCM both sides placed GND plane. :>
Would you like to help answer my pervious posted questions about the DC supply in output stage and the sound clipping reason ?
Welcome to all your feed back .
Old 7th June 2005, 08:44 PM   #23
R.I.P.
Hi CK
Where did this circuit come from, and was it ever proven ?
My tube books are in the roofspace, so;
Are these triodes hi-mu/high anode resistance types, because hi-mu triodes having a high anode resistance and used with high value anode resistors (160k resistor per triode and say just 1.5mA current) really will degrade your high frequency response ?
For hi-fi I would not go beyond medium anode resistance with a maximum 22k anode resistor per triode, though here the 5751 usage/performance might be intentional.
I don't like the capacitor coupling between the tubes and the mosfet bias chain. There is a substantial risk for the semiconductor circuitry to cause a partial and unequal rectification of waveform when driven to clipping. The triodes are capable of conducting more than the emitter resistors, and thus large amplitude tonebursts could cause an alternating zero level shift.
I trust that you have the 47 ohm resistor connected between the Q18 and Q19 sources, and not between Q18 source and output. This is hard to make out on the circuit copy.
Old 8th June 2005, 05:56 AM   #24
R.I.P.
Somehow I wrote 'emitter resistors' when there are none.
For those who cannot decode my ramblings I meant 'anode resistors'.
Cheers ........ Graham.
Old 8th June 2005, 06:07 AM   #25
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Non feedback is very good...go ahead, i am enjoying this thread.
But my friend Chocoholic image is out of phase...need some degres arrangement.
Carlos
Old 8th June 2005, 06:16 AM   #26
Default Hello Choco...long time without you here...welcome!
Your image had phase corrected.
60 degrees phase correction.
regards,
Carlos
Old 8th June 2005, 08:14 AM   #27
I have got it in few years ago at one of the HiFi column. Who also expressed no experience on it. Actually, this circuit is CJs EV2000 you can still find in their WEB. Where they explore it is same to the circuit behaviour. But what I got may not their final version or somewhat the value of components may changed. As a result I made it really without major problem.
5751 amplification factors in a range of 55 V 85. Detail can by obtained by an attachment.
Actually, R51=47ohm connected between Q18 and Q19 source, you may be interfaced by such fuzzy picture . A second point you see a 4 x 160k ohm anode resistors are in parallel therefore the resultant resistant is 40k ohm. Did you claim its resultant need to change as 22k ohm ? (The circuit PDF version will send to you by mail separately.)
DC supply at point B+ = 53V , D+ = 53V , E+ = 26V and Anode = 390V these are my personal used. I did not exactly follow the DC provision by the circuit, just change the zener reference voltage value. So you can find B+ is 80V provided. I through B+ will too high (110VDC) when I made the secondary output in series.
Old 8th June 2005, 10:47 AM   #28
R.I.P.
Hi Ck,
Quick note,
But you still have 160k per anode, and that is high for Hi-Fi.
Old 8th June 2005, 02:44 PM   #29
I exactly follow the schematic use 4 x 160k ohm (R31 - R34)parelleled together connect to the 4 single triodes they are shorted together.
Is it too big ? But what value should be used when 90vAC swing on the input stage ? It there R31-R34 and R27-R30 values need to be changed based on this requirement.
I intent to increase the output stage supply DC up to 80VDC.
About my hybrid nofeedback AMPHide this!Advertise here!
Hybrid nitelite Tubes / Valves 4 16th November 2013 09:32 PM
Hybrid Ply / MDF ? Renron Multi-Way 5 8th February 2007 10:49 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
another nofeedback amp fscarpa58 Solid State 41 7th February 2006 01:21 PM
Copyright ©1999-2017 diyAudio
