how many ways to stablise? - Page 2 - diyAudio
Old 25th May 2005, 09:10 AM   #11
Greg, could you send me an email giving some of your background as a designer? could be interesting.
thanks, IM
Old 25th May 2005, 09:33 AM   #12
Workhorse's Avatar
thanks, IM
Yes he would certainly help you as he is guru of amplifiers
Old 25th May 2005, 04:04 PM   #13
bscally is offline bscally  United States
Originally posted by amplifierguru
Yes kanwar, this is a reliable strategy with low impact on slewing rate and THD. I used this in my PA amp range of the '70's! The downside is that it bypasses the output stage so reduces loop NFB around this most distorting stage.
Who said anything about bypassing the OP stage?
The impact is that there is less loop gain to linearize the OP stage.
I have seen this method is employed with the an output stage with local feedback such as a CFP. However that can open it's own can of works if not treated properly.
Old 25th May 2005, 06:20 PM   #14
mikeks is offline mikeks  United Kingdom
Account Disabled
Originally posted by AndrewT
Read Dr Cherry, for ideas on differentiated loops.
http://www.diyaudio.com/forums/showt...489#post475489
http://www.diyaudio.com/forums/showt...498#post475498
Old 26th May 2005, 12:58 AM   #15
Banned
the vas must be stabilised more than any other stage especially against
p2 the reasons for this is in the details of the spice simulator that i have
programmed with my dos pascal software
phase shifts in this stage could be rendered negligible if only pcb is in
the equation of my spice simulator
cheers
Old 27th May 2005, 01:38 AM   #16
Account Disabled
Hi bscally,
I'll have to watch my phraseology in your presence. I meant that the loop gain was being redirected back to the input stage leaving less global NFB around the output stage for reduction of it's distortion. Same difference.
Hi Mastertech,
Yes - if your design has a Vas ( my latest doesn't - unless you include the front end chip), being a high gain stage it will need consideration of all it's foibles.
P1 - insert your zero here - P2
It cdr data,
I have activated my email button if you wish to contact me.
Old 27th May 2005, 12:01 PM   #17
darkfenriz's Avatar
one more possiility to stabilize:
in inverting mode- summing junction (resistor to resistor shunt) add the cap to the ground (dominant pole or pole-zero) so that the substracion is the slowest operation and keeps other stages free from saturation, TIM, ...
I see only pros...
comments?
Old 27th May 2005, 12:36 PM   #18
jan.didden's Avatar
I see only pros...
comments?
Hi Darkfenriz,
I think the disadvantage of this is that it increases the noise gain, and reduces the loop gain available for non-linearity reduction - basically you reduce the open loop gain at higher frequencies and thus the feedback gain. But it will work for sure.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 27th May 2005, 03:36 PM   #19
Hi bscally,
Apologies if I was TOO pedantic.
IMO .. Now this may be a whole different topic...
Another reason for attempting to linearise the OP stage.. or run substantially in class A is that the high (positive) and low(negative) OP stages gain false off as the devices switch off.
At this point additional feedback is needed to linearise the stage than at other points. No FB is a wonderfull thing but it is only a refuction of the error not a cancellation. (Please I don't want to debate the if it's reduced to the point of imperceptability it doesn't matter argument )
For an AB stage this generates 2nd harmonic distortion that is level dependant. When in the A part of the operating curve this is not present. When in the B part it is.
The concept of AB is that this distortion is no swamped by the main signal AND there is tolerencing to the OPS bias network.
Meandering back to topic...
The aim here is stabalise an unstable thing...
First ask yourself why it is unstable different topoligies have differnt solutions. Each is a set of compromises in it's own right and as such each needs different stabalisation.
Now by definition we start with a nested feedback loop system. So we have to analyze it as such.
Brian
Old 27th May 2005, 04:48 PM   #20
jcx is offline jcx  United States
Hi mikeks,
How about some substantive discussion instead of uninformative derision
In nested feedback you have to apply Bode’s multiloop criteria, individual loops are permitted to be “unstable” without the overall amplifier being unstable – if you are referring to conditional Nyqusit stability, Cherry brings this up himself, the existence of physical prototypes with scope probe traces in his articles strongly suggest some range of stable operation
There are only few hundred million counter examples to your claims that output inclusive and nested compensation can’t work
NE5532/4 compensation is described in these terms in Eschausier’s 1995 book “Frequency Compensation Techniques for Low-Power Operational Amplifiers”
The IEEE has more than a few papers in the “nested miller” genra
Other op amps use output stage inclusive compensation
LT1028/1128/1115 has a unity gain buffer type output stage inside the Ccomp loop
all common emitter/source types have to use output connected compensation
the TDA7294 block diagram shows the Cherry stlye output stage inclusive compensation (I would call the output devices “power transistors” in this chip amp):
http://us.st.com/stonline/books/pdf/docs/1057.pdf
“A significant aid in keeping the distortion contributed
by the final stage as low as possible is provided
by the compensation scheme, which exploits
the direct connection of the Miller capacitor
at the amplifier’s output to introduce a local AC
feedback path enclosing the output stage itself.
The New 2-ways. Spasticteapot Multi-Way 16 19th November 2006 12:39 AM
2 vs 2.5 vs 3 vs 3.5 vs 4 ways Sony Multi-Way 4 7th December 2004 03:27 PM
Copyright ©1999-2017 diyAudio
