Hello.
I am searching for a servicemanual or schematic for the integrated amplifier off Electrocompaniet ECI-4. Can any off you help me with that please? I can send you some great schematic in trade. Best regards Kim |
#2 |
Hello all.
If you got Electrocompaniet ECI-4 schematic and want to trade, then I scan one off these schematics for you: Classe cam350 monoblock Electrocompaniet AW100,AW180 AW250 and electrocompaniet preamplifier. Sony Nad Denon Marants pm14 Best regards |
#3 |
Hello there, I am searching for the same thing you were nearly 5 years ago, did you finally find it? If so, any chance you can share it with me? Thanks very much in advance!
#4 |
electrocompaniet schematics are like the loch ness monster..
everybody talks about it, but no one seems to have really saw it.. the only schematic i managed to get seems right for the toplology but wrong for some components values.. anyway, good luck.. |
#5 |
So the only way to fix anything really is to send it to authorized service center, since Electrocompaniet is not in the US?
#6 |
their schematic seems to be generic through the different amps they made...
so if you can get one genuine schematic, you can iterate according to your model parameters, power, supply voltage and so on.. basically, it s a triple serial differential... |
#7 |
I have several original schematics but not ECI 4 model
#8 | |
Electrocompaniet Ampliwire 100 (AW 100 AW100) different Versions I think, the same problem there is also here by the ECI4. Therefore I am not a very great admirer of this devices. At least all older models needs redesign in some aeras, both regarded the electronic components so as the circuit and layout design. Even if someone here post a circuit diagram, one should make his own schematic and accurately compare with the original printed version. Any detected differences should be resolved. And deficiencies in circuit design should also be respected. The reasons for darkened PCB aeras (hot spots through thermal overheating) should be also resolved (by newer versions of AW100 often to observe). Last edited by tiefbassuebertr; 18th February 2010 at 10:27 AM. |
#9 |
Thanks guys for the responses! I need the schematic to fix one of the blown channel of the ECI-4, everywhere else is working fine, just need the values to get replacement parts. If I can't get it, I guess I will just drop it on Agon for sale as is for a few hundred bucks. Unit in mint shape cosmetically, what a shame...
#10 |
Hi AudioBS,
What is the problem with the faulty channel? Which values are you checking? Can you post a pic of the area? Maybe I can help a bit. Thanks |
| DAC electrocompaniet ecd tweak? | ffarges | Digital Source | 1 | 17th December 2008 11:28 AM |
| Electrocompaniet Help | Andypairo | Solid State | 66 | 9th July 2008 10:13 AM |
| Electrocompaniet AW 250 AMP. | hogue | Solid State | 1 | 1st March 2004 05:48 AM |
| Hello from an Electrocompaniet Fan | PrimeCase | Introductions | 9 | 21st May 2002 04:02 AM |
| Page generated in 0.10247 seconds (87.50% PHP - 12.50% MySQL) with 10 queries |
