Old 21st May 2005, 03:31 PM   #1
jacquesl's Avatar
Default ETI-480 100W Amp .. please help
Jacquesl
I had built ETI-480 100W amps but I cant make it work the right way is runs on 50+50v 8 ohms load the 100 Ohms resistors "Test resistors" burn every time so I found a way to make it work I jumped the protection transister becuase I have the idea the problem are that. so can somebody please tell me to to get rid of that protection transistor, Q6 I disconected it and put a that varible resister in paralell with the C6 cap and i tried to get the voltage +- 3.5 V and in the RV1 place I put a 470 Ohm resistor and that all worked for a thew hours and them it gets unstable the two amps are om a heat sink with 2 pc supply fans so it keeps cool.
So after a thew hours were coms s sss sss sound out of the speaker output i tested it it's not my speaker, it even blowed up one of my small tested speakers shame hehehe, well anyway can somebody please help me to get that bugger of a protetion out of this amp.
Old 22nd May 2005, 06:22 AM   #2
MOER is offline MOER  United States
Default ETI amps
Dear Jaques
Can you post the schematic so we can see how to help?
Vlat hom flaffie!
Old 22nd May 2005, 07:11 AM   #3
Your problem is probably HF instability due to your construction - these modules were never designed to have the heatsink/outputs/drivers separated from the main board. Try twisting the wires to each transistor together ie. 3 twisted wires to each tansistor - this may help.
Q6 is not really protection, it is vbe multiplier to set and stabilise quiescent current - with this disconnected the output is in danger of thermal runaway.
Also, if your are using the original 2N3055/MJ2955 transistors, DON'T run them on +-50V - the original +-40V is pushing it.
Cheers
Graeme
edit: BTW, shouldn't this thread be in Solid State??
Old 22nd May 2005, 07:35 AM   #4
jacquesl's Avatar
here are the url of the website
ETI-480 100W
http://www.alphalink.com.au/~cambie/
Old 22nd May 2005, 07:35 AM   #5
jacquesl's Avatar
this are my front of my amp nice marantz I modified becuase it had blown and somebody give it to me. so I just going to use that casing but I like it
Old 22nd May 2005, 07:42 AM   #6
jacquesl's Avatar
I made one amp without putting that RV1 on parellel with the cap C6, and it worked by taking R14 and R18 out, but the amp do not have all the power it need, becuase the bass dissort so I think that R14,18 that are 47 Ohms must be a larger or smaller Ohms becuase im using 50v maby everthing are mixed up the orginal plans are 40v I dont know if it can make any diffrence but you newer know
Old 22nd May 2005, 05:13 PM   #7
jacquesl's Avatar
ok the one channel works now the other one I must still work on I'm waiting for the Power Transistors the only probleme I have.
I hear I a soft buzz on the speakers can somebody please tell me how to get that away
Old 26th May 2005, 06:26 PM   #8
jacquesl's Avatar
ok, I found al my error that humm or buzz it was a lose ground wire on the input signal.
Old 27th May 2005, 03:21 PM   #9
destroyer X's Avatar
Default Take a good look into that upgrade.
A friend constructed and sent me professional microphone recording and i perceive it sounds excelent.
This one, seems to be some upgrade.
I will construct one, i am finishing Íon Obelisk and will jump into this SC480
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 28th May 2005, 03:58 AM   #10
Greg Erskine's Avatar
Default Re: Take a good look into that upgrade.
Hey Carlos I beat you for once. I've all ready build a SC480 and I even played it once.
Actually I was surprised how good it was as I was not really expecting much from the 2N3055/2N2955 output devices. From time to time you can get a SC480 kit for less than A$40 each so I couldn't resist. IMHO Its not in the same ball park as you know what.
Greg Erskine
100w Stk nbcd Chip Amps 14 30th September 2009 01:36 PM
12v dc to dc 100w psu razordave123 Power Supplies 13 7th February 2006 04:29 PM
Evolve Amps 100W+100W Stuff 4 Sale WALTER BURKHARD Swap Meet 4 8th June 2005 10:57 AM
Eti-480 100w Amp Help Please jacquesl Solid State 24 27th February 2005 07:26 AM
100W amp Vivek Solid State 13 23rd December 2001 07:57 PM
Page generated in 0.65605 seconds (18.35% PHP - 81.65% MySQL) with 11 queries
