Old 5th September 2002, 07:23 PM   #1
Default Power supplies and safety
Hi, as I'm pretty new to audio equipment and power supply building, I thought I would ask you a couple questions about how you do it regarding safety and certifications.
Regarding power supplies:
For you without formal electronics education, how do you do it?
  • Do you take your chances, knowing you did a good job?
  • Do you build it, then get it checked by someone with formal education (engineer)?
  • Do you leave it to someone with formal education, detailing parts and layout?
While I'm pretty confident I coud get it right (the first time ), I also have quite a bit of respect for high power applications, having seen some (non-audio) faulty equipment.
My other question is regarding grounding. Most (all?) the amp designs I have looked at connects to the mains ground. As I am in the unfortunate situation of not having grounded outlets, I was wondering if anyone have any comments on that ?(Considering that the amps was designed with grounded mains
in mind)
As I said, I am confident enough in my skills (haveing built some low-power equipment) to know I can make it work, but I still want a second opinion.
Stein
Old 5th September 2002, 09:15 PM   #2
The one and only
Nelson Pass's Avatar
A. You take your chances, and find yourself an earth
ground, or at least don't stand in water while adjusting
it.
Old 5th September 2002, 10:36 PM   #3
sam9 is offline sam9  United States
sam9's Avatar
Default Good question
One place to start (I did anyway) is with G.Randy Slone's book on electricity and electronics (those words are in the title). The first few chapters includes step-by-step directions on building a power supply for testing amps and other projects. Part of the step-by-step is information on how to do this safely. I recomend actually building the project because you can actually use the PS later as a practical piece of test equipment and because when you are done you will have a pretty good idea of how to construct a PS for an amplifier project.
I also suggest something I added. I made a check list of each test described by Slone. I print out a fresh copy and follow it exactly for every PS I have constructed. If you do this and follow Slones safety recomendations religiously you should be ok.
One more thing to add. Choose a place to do the work and have a qualified electrician check out the mains service you will be using. DO NOT ASSUME your house has been wired correctly. Hot may be neutral and visa versa -- and just because there is socket with three holes does not mean you have a ground connection. You may infer I have had an unpleasent personal experience in this reguard! It's your butt- trust no one! KNOW!!
Old 5th September 2002, 10:38 PM   #4
sam9's Avatar
Default One more thing
I noticed you list you location as "Bergen". Is that Norway? I don't know how things are wired there. Get info and advise from someone locally who does. Especially about what is a safe ground there. U.S. practice (or Australian) may not apply.
Old 5th September 2002, 11:29 PM   #5
From someone who works with very high powered equipment every day, the most important thing you can remember is do NOT ground yourself!
There's something called the "one hand rule" where you always keep one hand behind your back. It's not always practical, but safe. It keeps you from leaning on something that will ground. If you do get shocked, you don't want the power going from arm to arm, arm to leg is much better (if you think about it, arm to arm crosses right past your organs, mainly your heart).
Electricity is dangerous, but almost every time I see someone get shocked (or have to read an accident report about it the next morning when I get to work), it's because of carelessness. If you're careful, and smart about it, you'll probably be fine.
Old 5th September 2002, 11:42 PM   #6
sam9:
I'll have a look at that book. Thanks for the reference. About the mains wireing, you are twice right. It's a bit different here in Norway (Yes, your geograpics knowledge is pretty good), and no, the wireing in this house has not been done properly.
Mr. Pass:
Yes, I'll probably have to do that. You say standing in water is bad, but holding a can of beer would be ok, wouldn't it?
Stein
Old 6th September 2002, 12:09 AM   #7
sam9's Avatar
Default beverages
Akavit (aquavit?) is better still - or is that your neighbor to the east?
Old 6th September 2002, 02:11 PM   #8
jackinnj's Avatar
Default Grounds and safety
It's probably a good idea to repeat the obvious. The following come from a couple decades in ham radio, audio and the odd job fixing o'scopes and electronics while a physics student:
The "one hand" rule is imperative. I know it's impractical, but it is a good idea to work with another person.
Grounds -- make sure that the ground lead connecting your service panel is at least connected to the "street side" of the water mains. Make sure that both the water meter and water filter (if you have one) are bridged with a #4 copper braid.
High voltages will jump, longer than you think too!
Clean circuit boards of flux, solder balls, dirt etc.
It's not a bad idea to stand on a rubber mat (although if you work with CMOS you will want to get one from Allied or Newark.)
Furthermore, stop when you get tired. I have seen this repeated on rec.radio.amateur.homebrew, on the PIC list and elsewhere -- a guy can't figure out what's wrong with his circuit at 3:00 a.m. -- he has the DVM probes on the schematic, not the circuit board!
Old 6th September 2002, 06:25 PM   #9
The one and only
And take off your wedding ring when you poke around
inside the amp.
Old 6th September 2002, 06:52 PM   #10
jackinnj's Avatar
Default Also
take the wedding ring off when working with Ferric Chloride, Sodium Hydroxide, Pottassium Permagnate, etc. I guess you could take it off in bars also, but I am sure that the XYL wouldn't approve.
Beginner's Gainclone, Safety and, The Power Supply Board (please contribute) danielwritesbac Chip Amps 118 18th June 2008 07:12 PM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 05:21 AM
HV power supplies santa Swap Meet 0 17th January 2005 11:52 PM
Regulated Power Supplies for Low Power Amps PTL60 Solid State 18 6th February 2002 07:24 AM
Page generated in 0.11030 seconds (81.96% PHP - 18.04% MySQL) with 11 queries
