#11 |
Iīm a swede living in Norway and I know from personal experience that the mains wiring in this country is different from back home in Sweden. Itīs a 240V system alright, but itīs 120V in one lead and 120 in the other and the fusebox have two fuses for each cirquit fused. So when I fex. turn the lightswitch off to hang a roof lamp or something one lead is still 120V. Finding this out standing on the top of a ladder, holding a heavy lamp, is not a nice experience! On top of all things, Iīve managed to repeat this more than once.
BTW, alcohol would be a pretty crappy electrolyte wouldnīt it? Suppose beer would make a greater hazard than aquavit in this respect. |
#12 |
I wonder how they do "ground fault interrupt" receptacles in Norway or Sweden. Pretty much standard gear on this side of the pond.
Seem to be quite a few Scandinavians on this board. I wonder if they appreciate how much Norwegians and Swedes are discussed on the National Public Radio in the US. Of course, I am thinking of Garrison Keilor from whom we learn of the sour herring and stinky cheese and the interesting relationships between the Lutheran and Catholic flock in Lake Wobegone, Minnesota.<p>and of course, the <em> lingua franca</em> in Minnesota is peppered with, what best could be called "Skandineglish"! |
#13 |
So, to sum up all the advices, use common sense, drink akevitt (That's how it is spelled in norwegian) and use a grounded plug.
Now, as I said I don't have a grounded outlet in my room. Running a wire frm the kitchen is possible, but only a short-term solution (and not a good one for me). Now, I have a perhaps unorthodox solution to the problem: I run pretty much everything electric from extension cords with muliple outlets, and they are all with grund plugs. If make an extension cord with only ground connected, plug it into one of these, and run it out the window to an iron pole driven deep (say 1m/3ft)m into the ground. Wouldn't this be sufficient? As a side note, what would using a dedicated ground like this do to hum loops? |
#14 |
Replying to myslef
Here's a crude picture of what I suggested above Green is ground |
#15 |
Hi AndersP
Seems to me it is a 2 phase electrical system. Is this the standard in Norway? Just curious. |
#16 |
There would be difference in potentialbetween mains groung and that ground..
| Beginner's Gainclone, Safety and, The Power Supply Board (please contribute) | danielwritesbac | Chip Amps | 118 | 18th June 2008 06:12 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| HV power supplies | santa | Swap Meet | 0 | 17th January 2005 10:52 PM |
| Regulated Power Supplies for Low Power Amps | PTL60 | Solid State | 18 | 6th February 2002 06:24 AM |
| Page generated in 0.08766 seconds (76.95% PHP - 23.05% MySQL) with 11 queries |
