drive output transistors with an IC
Old 5th September 2002, 04:19 AM   #1
Jared is offline Jared
Send a message via AIM to Jared
Default drive output transistors with an IC
http://www.national.com/ds/LM/LM12CL.pdf
Is this what the figure at the botom of page 8 is doing?
that design increases the output voltage, but not the current..
Are there any designs that take an IC and drive bigger output transistors to provide a high current amplifier??
Would such a design be very inferior to a standard layout? It seems to me like there must be a way to use a $2 IC to take the place of a lot of components in an amp and still allow a decent power rating (~250 watts)
Anyone have any idea's suggestions, explanations why this idea wont work etc. ???
thanks
(BTW tried to search, but Ic is too short for search engine !!)
Old 5th September 2002, 05:26 AM   #2
Dozuki is offline Dozuki
It would seem that this set-up also provides current drive. The print at the bottom states that it brings the output swing up to +/- 70V at +/- 10A. I'd say that this is pretty high current.
Seems to be two camps, 1 that scoffs IC's (OPAmps) and one that embraces them. I fall somewhere in between. While I can't see an IC being 'ideal' I'm of the opinion that they are usable and can generate acceptable results, even the lowly TL072. There is a lot of info on using various ICs for building amps. One way is to use IC's for the voltage stage and discrete components for the OPS (current amplification). A common TL072, a few resistors, a drive transistor, and a couple of mosfets are enough for an approx 15-25W poweramp. Not too bad for 15$ in parts (not including power supply). There are also ICs that are essentially 'amps on a chip' that can be used to build an amp. These can be parrelled or bridged to give higher outputs. I think that the PDF file that you pointed to is a good start for building higher powered amps in this manner. I admit that I don't understand all the topologies that the datasheet suggest and I tend to approach it from the OPamp as VAS point of view, choosing to use an OPS of my liking. If you could get an LM12 to swing 70 Volts without clipping as the datasheet suggest, you could theoreticly make a 300W amp.
-D.
Old 5th September 2002, 01:33 PM   #3
the lm12 swings +- 35 volts at 10 amps, that design swings it +-70 volts at 10 amps. how many watts is this ? 612 ? or is it more than just ohms law? This is not enough curent to drive a 4 ohm speaker tho, so could I just double/triple up the big transistors to provide extra curent capability?
Old 5th September 2002, 01:57 PM   #4
stadams is offline stadams
Default Not Cheap!
If you are considering using the LM12, it is not cheap, ~$30.00 as a single unit. I have seen it used in a couple of "high-end" car audio amplifiers that are manufactured by MMATS. You can use this device as an audio amplifier by itself and a few supproting components. I believe its good for 80W. However, I think its original design was for industrial control applications to drive motors, etc. If I remember correctly, you can parallel several together for greater output capability.
Don't forget the heatsinks!
Later,
-Todd
Old 5th September 2002, 02:57 PM   #5
i saw them for $18 online... but cannot seem to find them again !!
Old 5th September 2002, 02:58 PM   #6
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
The Amber Stereo 70 power amp used the LM391N-100 chip to drive the drivers for the output stage which consisted of 2N5886/2N5684.
I have several of these amps and they sound excellent.
Old 5th September 2002, 03:09 PM   #7
G is offline G  United States
G's Avatar
Default G
I would think that an IC with a Buffer IC inside the feedback loop would be acceptable to drive a power stage. Say a OPA627 and a BUF634 combo as a combination gain/driver stage. I've got a PCB layed out for this, if you would like I can send it to you. The board is about 2"x2.5" per channel.
Gavin
Old 6th September 2002, 02:15 AM   #8
Jared:
The equasion is a little more than ohm's law. For Wattage output it is:
(V*V)/Z/2 - z=speaker impedance. There is a thread discussing this if you want more info. My estimation of making a 300W amp was from the presumption that in the +/- 70V Schematic you could get a 70 swing without clipping. There is a possibility that you could get more, but as you pointed out the 10 Amps would not be enough for a 4 ohm load. You would need 17.5 amps for this.
The Datasheet for the LM12 shows a simple amp for audio that claims .01% distrotion, i'd say that ain't too shabby, but specs tell you nothing of the sound. I was thinking about the topology that you origianally pointed two and I came to the conclusion today that this topology is probably running the OPAmp in some form of Class B, swinging 70 volts into the chip in either direction as the wave form swung that direction. Again this is just guessing. Using this method might bring the distortion levels back up.
G:
I would love to see the schematic for the board that you have, the buffer in the NFB loop sounds interesting.
-D.
Old 6th September 2002, 02:57 AM   #9
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Post Serious opamp indeed
Here's a pretty solid opamp that would drive just about anything so it seems. Price is $9.88 US in quantity, so it's barely bearable.
ABSOLUTE MAXIMUM RATINGS
SUPPLY VOLTAGE, +VS to –VS 350V
DERATED SUPPLY VOLTAGE, +VS to –VS 250V
OUTPUT CURRENT, cont. within SOA 60mA
OUTPUT CURRENT, peak 120mA
POWER DISSIPATION, continuous 14W
INPUT VOLTAGE, differential ±16V
INPUT VOLTAGE, common-mode ±VS
http://eportal.apexmicrotech.com/mai...em_id=&f_page=
GP.
Old 6th September 2002, 03:18 AM   #10
G's Avatar
Here You go Dozuki.
Gavin
drive output transistors with an ICHide this!Advertise here!
Horizontal deflection (or high voltage type) transistors to directly drive ESLs? bigwill Planars & Exotics 121 21st May 2006 08:59 PM
