Old 14th May 2005, 11:07 PM   #1
Question Amplifier suggestion for college project
Greetings everyone,
I have been searching around for a medium power (b/w 30 and 50 W for 8 ohms), amplifier (or pre-amplifier + power amplifier), with a *fet output stage (if possible, using the IRF series), and also using "easy to find" components (although "easy" is pretty relative; btw, i'm from Brazil ) to build as a college project.
Elliott's project #101 (http://sound.westhost.com/project101.htm) seems to be perfect, but component values are not listed ... as this is a school project, i can't just buy the psb (unfortunately :P)
I have already found some schematics, but none seem to satisfy all (or at least most of the requirements above). I'd prefer a pcb-ready project, but this is not really a requirement...
Any special suggestions???
Old 15th May 2005, 02:04 AM   #2
Vai a este site
http://www.audiofanatic.it/Schemi/Ti..._finaliSS.html
DIYers de lingua Portuguesa:
Old 15th May 2005, 08:27 AM   #3
taj is offline taj
taj's Avatar
Default Contact Elliot
You never know. Why not send an email to Rod Elliot to see if you can just purchase access to his private area where the assembly instructions are? Just because you cannot use the PCB doesn't necessarily mean you cannot build his circuit.
I don't know what Rod policy is in the regard, but it certainly doesn't hurt to ask. His PCB prices are dirt cheap, given the quality of his designs, so purchasing a PCB and not using it, might also be an option for you.
..TAJ
Old 15th May 2005, 09:16 AM   #4
djk is offline djk
djk's Avatar
I wouldn't even give you a grade for building a design that wasn't your own.
The ESP design is for Lateral MOS only.
The IRF type FETs are very difficult to run in class AB without bias problems.
Why don't you take a look at the PASS Citation 12 Mosfet?
Old 15th May 2005, 01:12 PM   #5
paulb is offline paulb  Canada
Good thing you're not a teacher.
A link might be helpful.
http://www.passdiy.com/pdf/citation.pdf
Old 15th May 2005, 04:31 PM   #6
edl is offline edl  Hungary
edl's Avatar
http://www.audiofanatic.it/Schemi/Ti...W_IRF530_1.jpg
http://www.audiofanatic.it/Schemi/Ti...W_IRF530_2.jpg
Old 15th May 2005, 05:07 PM   #7
Actually, we are not supposed to design our own amplifier, as we don't have a good background on audio; this is not an end of course project; teacher's recomendations are: find a good, ready to use, design on the internet and build it
Old 15th May 2005, 05:07 PM   #8
Thanks for all the suggestions and comments... I really liked the Citation 12 (actually, the Mosfet 12, at figure 8).
I've read the file, but couldn't find a power rating for the amplifier... Something like 70W @ 4 Ohms?? What's the effect of decreasing the DC supply voltage (the suggested 42V is a little too high for me; would 30-35 be a good value? i'd be happy with an output power ~50W). Also, are the IRF130, MPSL51, MPSL01 easy to find? or are they obsolete by now? If so, any clues on replacements?
Old 15th May 2005, 08:09 PM   #9
Hum, that's weird... I've tried to simulate this circuit in pspice, and it doesn't seem to work: no matter how is the input signal (i simulated using a sine wave), the output is constant @ -6V
i double-checked the schematic, and couldn't find any problems
Old 15th May 2005, 09:54 PM   #10
pinkmouse's Avatar
If you can give up the fet outputs, you could build a Krell KSA50 clone.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
My GhettoBlaster college Project vinaltap Full Range 5 17th May 2009 03:01 PM
Suggestion for First DIY Project for Wife and I mlammert Multi-Way 13 15th September 2006 03:58 PM
Suggestion for my First Project gazolli Full Range 4 19th November 2005 09:07 PM
Any suggestion for cheapest SET amplifier project arnoldc Tubes / Valves 40 9th March 2005 09:05 AM
Page generated in 0.10895 seconds (80.29% PHP - 19.71% MySQL) with 11 queries
