#21 |
I whipped up a layout yesterday...it comes in around 3.75" square, which isn't too shabby. I need to tidy things up a bit, but I thought I'd post it to get some feedback. Thanks in advance...
gravity always wins |
#22 | |
Banned
I like this.. want to share the files ? |
#23 |
Sure...I'll post the .brd file tomorrow...I have that project on my work comp
#24 | |
Banned
Sweet thanks. J' |
#25 |
ble0t, I like your project a lot! It's much more compact than the board I purchased.
Can you please let us have the components' values and some specs? Thanks! |
#26 |
Here's the .brd file for it...I cleaned up the silk layer and a couple little things.
As for the values / specs, they are identical to those in the schematic in post #7 of this thread and to ESP Project #39. The one difference is that I only had room to use two limiting resistors in the soft start circuit, so you would probably want to increase the size/wattage of these two as compared to the project.
#27 |
HI,
how about radial power resistors to save space? 240v mains require about twice the resistance. Does that means twice the power dissipation?
regards Andrew T. |
#28 |
That sounds like a good suggestion...I could definitely give that a shot. Thanks!
As for 240V mains...currently, the primary side of the transformer is wired for 120V operation, although I could add some jumpers to make it switchable between the two. I'll work on it a bit over lunch and hopefully have an updated version later today
#29 |
OK...here's a go at the above suggestions/ideas...
#30 |
And the .brd file for anyone interested...
| ESP soft start circuit | 454Casull | Power Supplies | 19 | 29th May 2009 02:06 PM |
| Soft start + switch on PCB | smithy666 | Solid State | 29 | 4th September 2007 05:33 AM |
| soft start circuit | tsearay | Swap Meet | 0 | 8th February 2007 01:18 PM |
| ESP Soft Start Circuit | Alcaid | Parts | 4 | 25th February 2005 06:56 PM |
| Page generated in 0.10147 seconds (76.55% PHP - 23.45% MySQL) with 11 queries |
