Old 21st August 2005, 10:59 AM   #91
just noticed that the K2 unused poles are close to the ground protect track. What is the gap?
Q what gap do you need, 1.6mm?
regards Andrew T.
Old 21st August 2005, 11:10 AM   #92
There is a fused mains switch that disconnects both lines.
but maybe it would be better to disconnect both lines using the relais.
the unused pads of the relais are never high, so the gap is not that important i think.. it is 1.5 mm by the way..
thanks for Your feedback
Old 21st August 2005, 05:46 PM   #93
K2 unused pins go high when K1 is energised and K2 is low.
regards Andrew T.
Old 22nd August 2005, 10:48 AM   #94
ah, good point, didn't noticed that..
I changed the layout to accomodate other relay types.
all gaps between the 220V lines are 2mm or more
thanks
Old 22nd August 2005, 11:35 AM   #95
BrianDonegan's Avatar
Can you move R12 above R13 and get rid of the jumper?
Twisted Pear Audio
Old 22nd August 2005, 03:32 PM   #96
Good idea, thanks.
I've been staring at the thing for a long time to eliminate the jumper, but didn't see it..
I also did some more fine tuning
here's the latest version
ESP soft start circuit 454Casull Power Supplies 19 29th May 2009 02:06 PM
Soft start + switch on PCB smithy666 Solid State 29 4th September 2007 05:33 AM
soft start circuit tsearay Swap Meet 0 8th February 2007 01:18 PM
ESP Soft Start Circuit Alcaid Parts 4 25th February 2005 06:56 PM
Page generated in 0.10768 seconds (67.57% PHP - 32.43% MySQL) with 11 queries
