N-channel Current Gain Cell N-channel Current Gain Cell - diyAudio
Old 11th May 2005, 03:26 AM   #1
Workhorse is offline Workhorse
Workhorse's Avatar
Default N-channel Current Gain Cell
Hi everybody,
The circuit below act as an current cell, which has current gain but no voltage gain [Av=0.85]. This circuit uses an effective current source based biasing scheme and at input uses a p-channel mosfet and output uses 2 n-channel mosfets in pushpull manner in Class-AB or A [optional]. This circuit is self centered and very less DC offset will be present at the output.
Kindly give your views.
Turn Off the Lights ,Take a Deep Breadth and Relax , think about it in your mind.
Old 11th May 2005, 03:55 AM   #2
amplifierguru is offline amplifierguru
Account Disabled
Hi Kanwar,
Oh goodness me, I think this is not good karma because Nch will cross-conduct if not driven from similar source impedance.
Greg
Old 11th May 2005, 04:09 AM   #3
Workhorse's Avatar
Oh Guru of amplifiers have a mercy on me and save me from the impact of the dreaded cross-conduction. Strike the cross-conduction with your almighty power and destroy it! do something to save me from the cross-conduction
Old 11th May 2005, 04:27 AM   #4
Account Disabled
Oh goodness me, you can plead for salvation from the dreaded cross conduction but it will plague you! You must not use sloowww Nchannel as this will surely be your undoing.
Old 11th May 2005, 04:35 AM   #5
Workhorse's Avatar
Default welcome to party boys,
A slooow n-channel then where exist the forever faaast n-channel kindly show me the most vincent path to it with your farsighted heaven vision, i will definately pray for it or there will be another cause for its effect to be implemented,
Old 11th May 2005, 04:44 AM   #6
Account Disabled
You must be choosing your own path to follow and be finding your own wisdom in the dawning of the new enlightenment. Tis not for me to lead but for you to follow. You must be learning this in your own time, befitting your karma.
You may pray but your prayers will fall on deaf ears without the passion and dedication to find the truth.
Old 11th May 2005, 05:10 AM   #7
Workhorse's Avatar
Kindly give the reasons to validate your point regarding the cross-conduction so that i could learn more about it in this circuit.
If you really feels that this circuit is suffering from cross-conduction
Then i have something to show you , look at the circuit below, is this also suffering from cross-conduction, if yes ,you are the winner in the game and someone or may be many of the others who dont know it dont agree with that all are the loosers.
here is a checkmate, be winner and In my opinion you are the winner and champ of the game.
Its a serious matter so please give the answer
Old 11th May 2005, 05:22 AM   #8
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Must be a full moon tonight.
Old 11th May 2005, 05:36 AM   #9
Account Disabled
Hi Kanwar,
Yes I know it is Pch feeding Nch - but it will need to swing with that upper Nch all the way up! And, while the upper one can discharge through the Pch pull down, not so the lower one which only has a R to ground so a slow discharge.
How many coulombs for your N channels again?
Old 11th May 2005, 05:40 AM   #10
Workhorse's Avatar
Thats right, i agree with you, but is this all same for the second circuit also, kindly comment.
N-channel Current Gain CellHide this!Advertise here!
Closed Cell Vs. Open Cell Foam-Which For Damping Loudspeakers? kelticwizard Multi-Way 25 10th July 2013 03:55 AM
PS Audio "Gain Cell" loudandclear Solid State 17 7th April 2010 03:53 PM
A high Current wide bandwidth Transconductance Cell Workhorse Solid State 0 11th June 2006 10:42 AM
Copyright ©1999-2017 diyAudio
