PPP transistor ?
PPP transistor ?
Old 3rd September 2002, 01:08 AM   #1
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Default PPP transistor ?
I threw this design togther, but parts are probably wrong. (I'm a tube guy, after all.)
The 2SB631 & 2SD600 are complementry.
ratings are: 100v, 1amp.
the 2SC3502 is 200v, 100mA. they are all TO-126 packaged
Let me know what you think. I can find the datasheet for the output transistors if you guys need them..
Old 3rd September 2002, 01:52 AM   #2
dhengkoel is offline dhengkoel  Indonesia
dhengkoel's Avatar
Dear colt45:
You love minimalist ... I love minimalist too ...
Your schematic very simple ... but transistor can't apply to circuit as simple as the tube can be ...
I attached the schematic as close as your design ...
regards:
ragil.hastomo
:: The last but not least ::
Old 3rd September 2002, 03:55 AM   #3
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
A note to Colt45, the 2SB631 is upside down in your diagram, it won't work with the collector being positive in comparison to the emitter...
EDIT: also, you need to bias the output transistors or you'll have ugly crossover distortion.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 3rd September 2002, 04:17 AM   #4
oops
how?
PS: did you get unpacked yet?
Old 3rd September 2002, 04:59 AM   #5
Dozuki is offline Dozuki
Try to re-arrange your schematic to look like that of dh's. The Diodes in the schematic are for biasing the OPS. 1N4148's should work fine. You could also use a Vbe multiplier (tansistor and pot) for more control and better sound, but play with the diodes first. You should be able to mock this up pretty quick on a breadboard and tweak the biasing to get a good sound.
what you should end up with is something similar to:
-D.
Old 3rd September 2002, 10:38 PM   #6
Duo's Avatar
Okay, I see that Dozuki has successfully demonstrated a possible biasing scheme for you. This is to keep the transistors in conduction so that they don't turn off when the signal goes between +0.7 volts and -0.7 volts, in other words, crossover. Basically, one transistor is supposed to turn off after the signal has turned the other one on, but not before, this way the gap is filled and there's no crossover distortion. Each diode drops about 0.7 volts, this means that accross the two you'll get 1.4 volts which is just the right amount to turn both transistors on barely. The resistors from the + and - rails to the diodes are to keep the diodes themselves biased and provide the current that will end up biasing the output transistors. I hope this explains what we have shown you...
PPP transistor ?Hide this!Advertise here!
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 10:34 PM
Transistor Id glen65 Solid State 13 4th March 2006 10:31 PM
503 transistor dazling69 Solid State 5 18th September 2005 09:03 PM
Best Transistor? samsagaz Solid State 13 18th October 2004 09:22 AM
Transistor ID EchoWars Solid State 6 24th January 2004 12:45 PM
