Old 6th May 2005, 08:32 PM   #11
Send a message via Yahoo to northsiderap
Default A lot to digest now....
I liked the links...
Dr. Leach has more than I'll digest in a long time I'm certain...
Check out the TPT Clock and that group of links. Interesting stuff, it seems that people actually buy these things...
I finally can work out the noise figures, which was the point of my original question! Any suggestions on the proper measurement of a working model would be nice.
I'm not sure what 'Referenced to Input' means for simulation noise measurement..
I assigned a node after my DC blocking cap right before my simulated load resistor...The voltage source being measured was the +/-2 mV sine wave sweep from my signal generator at input.
I have now assigned the node to different places, and found out that much of my noise comes from my DC BJTs. That's what I get for trying to re-invent the NEVE... I think I'm going to try to squeeze a little more gain out of the JFET, but leave out the source bypass capacitor if possible.
Thanks for all of your help
--> Jim <--
==>NorthSideRap.com<==
Old 6th May 2005, 08:45 PM   #12
jackinnj's Avatar
Default Re: A lot to digest now....
One of the great and easy ways of supporting an academic is to purchase his books -- in this case "Introduction to Electroacoustics and Audio Amplifier Design" by W. Marshall Leach -- available in paperback.
Old 7th May 2005, 08:48 AM   #13
Offourse..I made an error.... I am so used to calculate these things that I immidiately changed it to 5fV^2/Hz which is 70nV/srqt(Hz), a slightly high but possible figure.. 5pV^2/Hz is not.
But offcourse 5pV^2/Hz = 2.23uV/sqrt(Hz)...
Still, the method I propose is correct
BTW
2.23uV/sqrt(Hz) is alot of noise.... this cann't be right? Only if you have gain in the thousends then is might be right. Or are you simulating openloop? If you gain is 15 then your Equivilent Input Noise (EIN) is 149nV/sqrt(Hz). An input stage usually has about 10nV (or between 3nV and 30nV) ...
Are you sure it says pV and not fV?
Noise Figures for MC Preamp (Inputs Shorted) thermionic Solid State 20 19th December 2008 06:19 PM
Lissajous figures rtarbell Everything Else 1 28th October 2005 01:23 AM
DC offset figures johnm Chip Amps 7 6th February 2004 01:01 PM
Distortion figures for analog muxes eplpwr Parts 32 4th June 2003 03:23 PM
help, need some figures Alex_B Multi-Way 54 9th December 2002 12:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
