about heatsinks
about heatsinks
Old 4th May 2005, 11:14 AM   #1
bigpanda is offline bigpanda  Hong Kong
Default about heatsinks
Can anyone please kindly provide info about these :
1. With the same x-section, how would the thermal resistance changes as a function of the length (or at least a rough estimation?) I guess that it would not be so simple as 1/2 the length, double the resistance?
2. Any recommendations for the base thickness?
3. What about the fin thickness?
4. If we were to use an angle bracket, what would be the reasonable thickness? I have been using 2.5mm -- 4.5mm
5. Assuming there are fins all over the base instead of some 'blanks ' like what's in the picture, how much better can one work with vertical fins instead of horizontal fins, assuming the fins' surface area are the same in both heatsinks.
Thanks for your input.
Old 4th May 2005, 11:37 AM   #2
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
about heatsinks
Default Help is on the Way
Good explanation is here:
http://sound.westhost.com/heatsinks.htm
SPreadsheet for calculation is here:
http://sound.westhost.com//download.htm#hsink
Look for heatsinkzip.
Hope this helps!
Mark
Mark
www.kravchenko-audio.com
Old 4th May 2005, 03:34 PM   #3
R.I.P.
the heatsink dissipation increasing in proportion to the square root of the length. i.e.double length gives about +40% thermal capacity & 4 times length gives about double capacity.
The fin length should be about 10 times the root thickness and can taper to about 30% to 50% thickness at the tip.
for natural air cooling spacing about 8 to 10mm.
fins sideways reduce dissipation by about 20% and lying on its back reduce about 50%.
The thickness of the angle should be enough to stop it bending when bolted tight, about 6mm.
Taking a guess at base plate thickness and using the fin dimension I think the base plate radius from the heat source should be about 10 times the thickness i.e. 200mm square with one transistor in the middle would require a plate about 10mm thick.
regards Andrew T.
about heatsinksHide this!Advertise here!
To-3 Heatsinks sandstorm33 Swap Meet 8 6th February 2008 04:33 PM
Heatsinks DD_Davo Chip Amps 2 13th April 2005 01:00 PM
4 sk 102 heatsinks. what amp can it be used for?? wuffer Pass Labs 28 24th November 2004 07:38 PM
Heatsinks Peter Daniel Swap Meet 19 3rd February 2004 11:08 PM
Heatsinks for DoZ ultrachrome Solid State 0 4th February 2003 09:23 PM
