Running amps unloaded
Old 12th October 2012, 02:01 PM   #31
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I'm going to resurrect this thread because I'm planning on trying something similar, but I wanted to run it past everyone, just in case.
I have a 7 channel Onkyo receiver and I'd like to experiment with some EQ on my center channel, but unfortunately, it lacks pre-outs.
What I'm planning to do is use a basic L-Pad of resistors to convert the output to line level, so I can connect this to an external DSP and amplifier, but this resistance would be all that's across the output of the center channel, something like 10k ohm.
Anyone think this would make the receiver grumpy?
Old 12th October 2012, 03:06 PM   #32
you should be able to intercept the INPUT to the power amplifier of the centre channel.
Feed that into a 100k Rin buffer and you have a good output that can drive a cable.
regards Andrew T.
Old 12th October 2012, 06:06 PM   #33
jitter is offline jitter  Netherlands
jitter's Avatar
I would not expect it. The SS amps I know run the headphones off the power amp through series resistance or voltage divider and work perfectly with speakers disconnected. OK, resistance is a little lower than 10k, but I don't think that makes much difference.
I must say that I like AndrewT's idea of intercepting the signal where VAS and power amp (CAS?) interconnect, though.
Old 12th October 2012, 06:32 PM   #34
DrDyna's Avatar
Agreed, that would be ideal. There's enough room on the back to have 2 rows of 8 rca jacks for pre out, amp in that could be jumpered or not, but I think that would require some fairly hefty surgery on the receiver.
I'm not against trying I suppose, maybe I'll pull the top off in the next couple of days and see, perhaps I'll get lucky and the power amp board is connected to the rest of it with cables that can be easily tapped.
Old 13th October 2012, 06:52 AM   #35
jitter's Avatar
Which model is it? Perhaps we can find a service manual and have a look too...
Old 13th October 2012, 10:30 AM   #36
intercept at
not surgery
inside the guts of the power amp.
regards Andrew T.
Old 13th October 2012, 11:40 AM   #37
jitter's Avatar
A question just arose. Wouldn't a DSP in the centre channel only create a delay with respect to the other channels?
Old 13th October 2012, 11:45 AM   #38
DSPs are being adopted and recommended for everything these days.
I am a digital ignoramus, but couldn't we use the dsp to create a negative delay? They allegedly can do everything else.
regards Andrew T.
Old 13th October 2012, 12:13 PM   #39
MagicBox is offline MagicBox  Netherlands
You'd be a trillionaire with such a DSP because you'd have to go back in time DSPs generally queue up the sound in order to process it properly considering the time domain, then perform their 'trick' and make sure the result is aligned time-wise before it goes into the DA converter. Only if all channels are delayed by inserting a digital time buffer, you could achieve negative delay for one by extending the delay for others. It's all about relativity, even time-wise.
Negative Feedback: The Need for Speed
Old 13th October 2012, 01:10 PM   #40
DrDyna's Avatar
The MiniDSP I'm planning to use has ~1.5ms delay. I can counteract that by changing the "distance" setting in the AVR higher by 2 feet and moving them around a tiny bit, or just re-running Audyssey and letting it re-adjust the speaker delay, which is what I did to get my subs (which also go through the MiniDSP) back in phase/time.
intercept at
not surgery
I think you've misunderstood what I have to work with. I've got an AVR (Onkyo TX-NR609) which gets signal from HDMI and has only speaker level outputs. My plan was to use a pair of resistors to pad down the speaker output (because there's no other output) to line level, run it into one of my MiniDSP's unused channels, do a little processing and then feed it into an external amplifier.
If the AVR had pre outs, this would be a non issue, but what I'm planning to do would mean that the center channel section of the amp in the AVR is only seeing ~2k ohm rather than the 6 ohm center channel speaker it has on it's outputs now.
Running amps unloadedHide this!Advertise here!
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 03:34 PM
Unloaded LM317/337 behaviour philpoole Power Supplies 20 12th March 2008 10:15 PM
6AW6A, Unloaded rdf Tubes / Valves 13 13th October 2006 05:39 AM
How do SS amps feel about being unloaded Bill Fitzpatrick Solid State 3 5th August 2003 08:04 PM
Copyright ©1999-2017 diyAudio
