Running amps unloaded
Old 29th March 2003, 01:32 PM   #21
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
Originally posted by trwh
Hi I have built my LM3886 PA amp though, here's a pic.
wow man.... i jast love your AMP-PIC......
how much it is cost to u to build this amp...?
Old 29th March 2003, 06:37 PM   #22
trwh is offline trwh  United Kingdom
trwh's Avatar
Hi DJ.
The amp didn't cost much to build - I used spare / salvaged parts wherever I could. The main construction costs were: the heatsink (from RS), the PCBs from Rod, the toroidal transformer (very cheap from Rapid Electronics), the reservoir caps (budget types from Rapid again), and the chips themselves (from RS). A lot of the components, like the bridge rectifier, connectors, limiter circuit, etc. were taken from my failed Velleman kit.
All in all, if I were to make the amp again, it would probably cost me around £120-130UK.
Tim.
Old 29th March 2003, 07:22 PM   #23
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The output RC network will want to be something more like 5 ohms @ 3W and .1uF. 100nF is probably too low.
Old 29th March 2003, 07:32 PM   #24
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default The Nanofarad....
0,1uF = 100 nF .... (1uF =1000 nF)
Jorge
Old 26th June 2008, 11:15 PM   #25
lynchmob666 is offline lynchmob666  United States
trwh
you said you were never able to get the velleman kit stable. Is this even when connected to the speaker?
I suppose being surrounded by valve amps has brought me to expect needing a speaker load. Personally I have found amp designs that were marginally stable to sound better with flatter frequency response.
Old 26th June 2008, 11:35 PM   #26
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default Re: Running amps unloaded
Why should there be any problems running a solid state amplifier with no load on the output? I know tube amps need loading at all times, I think to prevent voltage spikes being fed into the output stage due to ringing in the transformer.
Some people may remember reading about my difficulties with the Velleman K4005 amp - I have since been told that the amp kept overheating because I was conducting my tests with the unit unloaded. Is this poor design or a common phenomenon? I run my P3A amp in “mute” mode (i.e. no speakers connected) for hours on end, and it doesn’t bat an eyelid. Can someone explain this more fully to me?
Thanks,
Tim.
Sounds to me like a bias setting problem.
I can get my MOSFET amp to run hot if I turn up the bias.
This increases the standing current throught output transistors even if there is no load.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 27th June 2008, 03:30 AM   #27
ionomolo is offline ionomolo  United States
ionomolo's Avatar
Send a message via MSN to ionomolo
My parents had a very old very low quality turntable (bettor) that broke each time it ran unloaded.
The effect was fast and we had several repairs when one of the channels did a bad contact after cleaning it. The last time it failed the guy at the technical service said he could not repair it because he could not find spare transistors, so they probably were germaniums and the amp perhaps was trasformer-coupled push-pull. I doubt it was class A as it did not get very hot.
In class A single ended the dissipation on the active transistor can double if the amp is unloaded.
Old 27th June 2008, 06:57 AM   #28
h_a is offline h_a  Europe
h_a's Avatar
How should this be? Even if there's a load connected, there's no current through it (with no input signal) - so effectively (without input signal) the currents with and without load are the same.
Otherwise you would burn dc through the speakers.
Or are you talking about transformer coupled designs?
All the best, Hannes
High Octane phono preamp Wiki
Old 27th June 2008, 07:21 AM   #29
ionomolo's Avatar
When i refered to class A single ended (on ccs) amps i was talking about amps with input signal. I don't remember whether the turntable needed to have any input to burn, but i remember it was very fast.
Old 27th June 2008, 08:48 AM   #30
h_a's Avatar
Ah, I see.
But with constant current source the active part will see also with input signal only the standing current - except you're talking about the Alephs
But don't worry, I understand what you mean!
Running amps unloadedHide this!Advertise here!
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
Unloaded LM317/337 behaviour philpoole Power Supplies 20 12th March 2008 09:15 PM
6AW6A, Unloaded rdf Tubes / Valves 13 13th October 2006 04:39 AM
How do SS amps feel about being unloaded Bill Fitzpatrick Solid State 3 5th August 2003 07:04 PM
