Old 3rd May 2005, 05:55 PM   #1
gengis is offline gengis  United States
gengis's Avatar
Default Sanken 2SC2922 amp Schematic?
HI,
Has anyone work on or seen an amp with around 4 pairs or more of the Sanken 2SC2922/2SA1216 output transistors?
I would like to build one with those output devices, around 200W@8 minimum.
Old 3rd May 2005, 09:00 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Found one class A and one class D:
http://home.no.net/andiha/articles/audio/claclassa.htm
http://www.soundlabsgroup.com.au/lca..._technical.htm
I can't comment on the amps though.
/Hugo
Old 3rd May 2005, 11:34 PM   #3
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Dieter Burmester's 828 amplifier used a bunch of 1216/2922 in the output.
The amplifier was rated at 200 in 8.
It would be nice if you could get your hands on the schematic of that one, so would i.
Looks like Sponge Bob has killed another thread.
Old 5th May 2005, 03:09 PM   #4
K-amps is offline K-amps  United States
K-amps's Avatar
The very nice Luxman M-117 and M-03 used 3 pairs of those Sankens. 80vdc rails 200wats 8e.
Those have hfe of about 30+ on the other hand Sanken's own A1494/C3858 (56?) are 200v devices with gain of over 50+ and are pretty good sounding.
K-
Old 5th May 2005, 06:26 PM   #5
2SA1494 and 2SC3858.
The Stage Accompany SA1600 PA amplifier i used at home a couple of years had those, 12 per rail.
2 times +300 in 8.
The 1216/2922 are twice as fast though.
I still have a picture somewhere, see if i can find it.
Old 5th May 2005, 11:57 PM   #6
gengis's Avatar
Mr. jacco vermeulen,
Enjoy your posts.
What does Symphonic Line by Rolf Gemein uses?
ps. I have 2 of 90 million Chevy small blocks in my garage.
Old 6th May 2005, 09:59 AM   #7
Rolf Gemein favors Toshiba for a long time.
After the traditional numbers are no longer available he uses the Toshiba 2SA1943/2SC5200 for his RG series amplifiers, uses Toshiba's for the drivers too.
Rolf Gemein puts a lot of emphasis on hardware.
He is one of the few who has been wrapping toroid transformers in MU shielding, right from the start, which makes his amps pretty expensive,imo.
And separated PS supplies, apart from that no real exotic parts, the clamps for the electrolytic PS capacitors in his amplifiers are more expensive than the BH caps they hold.
It is nice to read that my writings can be of some use ocassionally, Gengis, thanks.
ps i have 1 of 90Mil as a shortblock in my hobbyroom, one day i'll have it chromed, does it show i lived in the US ?
Old 6th May 2005, 10:24 AM   #8
The devices of the SA1600
Old 6th May 2005, 10:32 AM   #9
Pictures of the Symphonic Line RG 10.
In a 2003 article i read that RG uses these devices only in all of his models.
PS
GengisK, i noticed you have the magic B word on your profile.
I have exotic African Bubinga wood drying in the loft of my garage, to construct a 7.5' x 3.5' diningroom table.
A sandwich construction using epoxy resin for glue, estimated weight around 350lbs.
I am not your clone, am i ?
Old 6th May 2005, 10:58 AM   #10
sajti is offline sajti  Hungary
SA has some nice amplifiers. I used some of them.
2SA1494/2SC3858s are very good transistors. I made 4 amplifier moduls with them. Good sounding, and very reliable. I prefer them over the 5200/1943 pair
sajti
Sanken 2SA1216 and 2SC2922 (again) len_scanlan Swap Meet 0 29th March 2007 08:34 PM
Sanken 2SC2922 & 2SA1216 quasi Swap Meet 2 27th March 2007 10:26 AM
Sanken 2SC2922 datasheet. beppe61 Solid State 18 29th January 2006 02:49 PM
Sanken 2SC2922 - max peak current delivery. beppe61 Parts 3 26th January 2006 11:56 AM
FS: Sanken 2SA1216, 2SC2922 power transistors len_scanlan Swap Meet 1 13th January 2006 04:41 PM
Page generated in 0.11661 seconds (79.83% PHP - 20.17% MySQL) with 11 queries
