Hi there,
This may seem like a silly question, but i can`t find the answer anywhere. I have a mixing desk that supplies phantom power +48V I use a condensor mic that is powered from the mixer. Now what I want to do is to put a samson s-com compressor/limiter in between the mixer and Microphone. Will the phantom power damge the compressor? and will the power actually get to the Mic? Cheers for the help. |
#2 |
Did it Himself
The compressor should have DC blocking on it's output so you should be safe. However, the mic will no longer be powered unless the compressor can supply phantom power.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
You need to use the compressor on an insert or FX send/return.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 | |
From s-com manual: |
#5 | |
#6 |
Pinkmouse has it right. Effects always go in the send-rcv patch. I haven't seen many consols that supply phantom power that do not have send-receive patch points. That's what the instructions indicate as well.
-Chris |
#7 |
Account Disabled
I have worked on a commercial 'capacitor' mic preamp and the vagaries of supply.
Despite such limitations, it is possible, using constant current sources in the supply feeds, to obtain substantial overload margin/headroom but such a tack is rarely taken by either mixer companies or mic manufacturers. Obviously there are issues of noise when introducing a comp/lim into the chain at such an early stage especially given that the good mics only buffer the C and don't amplify at all. |
#8 |
Oh yeah. Can you imagine how much noise there will be using a line device at mic level and amplifying it? Never mind it probably won't compress at all at mic levels - including a noise gate might make it permanently quiet though!
-Chris |
#9 |
Account Disabled
Exactly!
You would need a dedicated mic preamp/com/lim and then go in on a line level. |
#10 | ||
if the console we're discussing here isn't equipped with a channel insert point then it is also unlikely that there would be an "on-off channel assign" switch. Also, the FX send is always placed after the channel fader, which means that you can't assign only the compressed signal to the mix out (thru the FX return) without sending the (uncompressed) original signal thru the mix buss. A better idea might be using Aux out, which is pre-fader assigned (if the console has one). Quote:
Regards, Milan |
| Diy Mic preamp with 48v phantom power | cheeseburgerjoe | Parts | 12 | 16th September 2010 11:33 PM |
| phantom power for condenser mic | patknk939 | Everything Else | 5 | 21st September 2008 07:07 PM |
| reducing phantom power | Sillyboy | Everything Else | 3 | 5th June 2006 03:31 PM |
| DEQ2496 for phantom power? | mazeroth | Multi-Way | 10 | 5th January 2006 04:51 PM |
| Using the phantom power | Gabevee | Instruments and Amps | 2 | 29th July 2005 05:32 AM |
| Page generated in 0.10139 seconds (76.53% PHP - 23.47% MySQL) with 11 queries |
