well
it is not working as you may have supposedsimple, maybe a bit experimental mosfet one burns one resistor and I don't know why can this be caused by output mosfets failure?? output voltage is ~3V please help me wiser ones best regards |
#2 |
Did it Himself
Put a very high value resistor across C5 to reset the integrator when power is off.
If the 470R resistor is burning then both upper and lower driver transistors must be conducting, try and trace what could be causing this.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
The one and only
try shorting across Q7 and see if the 90 volts is still there.
#4 |
thank you
is the whole project 'acceptable' ? |
#5 | |
The one and only
#6 |
if you want to avoid wasting money in destructed mosfets, use Zener protection diodes. One between emitter of Q10 and output. Another onebetwwen the output and the emitter of Q? (PNP complementary to Q10). You can use Zener voltage about 2 volts lower than the max rated VGS of the IRF mosfets.
If you destroy zener diodes it costs less than the IRF... |
#7 |
Hi darkfenriz,
Check R24, R25 for open as well as the 0.22R resistors. If you have that much across the 470R resistor, Q10 and it's compliment are either on or could be in reverse E-B breakdown. I'm fairly sure you will find a few transistors shorted. An open PCB connection could change things though. -Chris |
#8 |
thanks all
one more question: what will be minimal zener current thru 0.5W 47V zener diode? I have less than 1mA I'm affraid. BTW: all I wanted from this project was to keep output at low feedback with minimal number of stages. I used inverting mode making summing junction the slowest part of everything by means of pole-zero compensation. This should work nice in terms of low TIM and little interference with speaker back EMF, especially HF component of this signal. What do you think? regards |
#9 |
Mr darkfenriz,
you have shown such a "guru" approach on this board when answering other posts, and now you need help? Anyhow, your design is going to have an awfull PSRR Redesign it and then we can think about the "problems"! Regards Michael PS. the "other issue" is somewhere between U4 and Q1//Q3 stages, and is also part of the "problem" you mentioned!
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears" Michael 29th January 2010 |
#10 | |
thank you Ultima Thule
Making it is so inexpensive and simple, and makes amplifier "don't worry" about PSRR aside from efficiency issue. Thank you for suggestion, time will tell if it is going to have low noise or not. best regards |
| Page generated in 0.10072 seconds (76.84% PHP - 23.16% MySQL) with 10 queries |
