Need help quick please! P101 bias related
Old 25th April 2005, 11:56 PM   #21
brianuk is offline brianuk  United Kingdom
Sounds like goodstfuff, or should I say it will do.
Good game Shinobi x x x x x x x x if thats what the name is from.
Goodluck with the project
Old 26th April 2005, 12:39 AM   #22
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Yep taken from the very same arcade machine, my personal favourite from the 80's, a top game. Big fan of Starwars too so that's how it figures.
Cheers.
Old 26th April 2005, 12:59 AM   #23
ShinOBIWAN's Avatar
Default Re: Re: Need help quick please! P101 bias related
Originally posted by rabbitz
You probably already have the answer but turn VR1 CW (clockwise) to get minimum resistance. Check with a DMM from the single pin to the 2 joined pins to be sure. BTW, you've got a 20K in your post.... typo? as should be 2K.
I'd be interested how the final bias voltages come up as I didn't get close to the documented values across the 100R test resistor.... a lot of others haven't either. With min resistance on VR1 I was getting 0.68V-0.85V and on the final 2.68V-2.87V. Amp works well without any problems.
Cheers
Sorry missed this one!
Typo with the 20K I did mean 2K
Voltages across the resistors with minimum resistance on VR1 and using the 58VDC supply was 1.84v, after adjustment ~3.87v. Why are your so low? I presume since you are happy that it doesn't really matter.
Measuring across the speaker output reveals 4-5mv.
I have made some changes to the standard component suggestions, I'm using black gate electrolytics and also using Exicon fets after Rods recommendation that they are quite possibly better sounding than Renesas/Hitachi parts.
Old 26th April 2005, 01:43 PM   #24
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Works well with no problems so not an issue. I've seen a few posts around with lower voltages when doing the bias. Good to see someone with a higher value... maybe component choices... who knows.
Need help quick please! P101 bias relatedHide this!Advertise here!
quick question on fixed bias sorenj07 Tubes / Valves 3 6th August 2007 03:26 PM
esp p101 djronbxs Solid State 2 6th January 2007 02:02 AM
Setting the bias on an ESP P101 still4given Solid State 17 31st January 2005 06:36 PM
p3a bias trouble, quick question :) Mattyo5 Solid State 13 13th May 2004 09:03 PM
quick bias tolerance question...across source resistors Mattyo5 Solid State 6 12th October 2003 12:09 PM
Copyright ©1999-2017 diyAudio
