#11 |
Nope, at this stage it shouldn't make a blind bit of difference...
If you turn up the output voltage to the maximum, does the traffo still get as hot?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#12 | |
Hard to tell if the transformer is hotter running higher voltages on PSU -- its already too hot to hold you hand on for any length of time. I guess its a problem with the PSU but it should be childs play to connect it. Follow AC wiring diagram in the PSU instructions, simple as. |
#13 |
Actually I don't have the PSU connected to GND(earth).
Would this cause the heat? Looks like it would since AC2 and AC3 go straight to GND. |
#14 |
Well, I can't think of anything else it could be, but I was at work at eight this morning, so I am a little tired and my brain may not be working at 100%
I suggest you get some kip like I'm going to do and look at it fresh again tomorrow. Night night! :edit: AC2 and 3 are ground! Voltage is all relative!
#15 | |
#16 |
Did! See above!
#17 | |
Should I connect the GND output from the PSU to the earth? Would this cause the heat, since I've omitted it for testing? Cheers and have a good nights kip! |
#18 |
Can't see how, but I can barely see my hand in front of my face at the moment. See you tomorrow!
#19 | |
#20 | |
What is the line frequency? If it's 50 Hz, and you have a 60hz xfmr you need an xfmr. |
| How much to pay for torroid in UK? | andyburlow | Chip Amps | 6 | 22nd March 2009 07:11 PM |
| small crack in torroid!!future of torroid? | sagarverma | Power Supplies | 24 | 8th November 2005 05:22 PM |
| Torroid vs. SMPS | ChocoHolic | Power Supplies | 55 | 21st August 2005 02:34 AM |
| Ceramic Resistor Max Temps? | Zero Cool | Solid State | 10 | 10th July 2005 01:37 AM |
| Page generated in 0.09375 seconds (80.14% PHP - 19.86% MySQL) with 10 queries |
