diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   300w mos-fet amp (http://www.diyaudio.com/forums/solid-state/56011-300w-mos-fet-amp.html)
raszvan 24th April 2005 03:53 PM
300w mos-fet amp
i need a mos-fet amp schematic...with pcb...
rms-aprox 300w
i can't find one...:xeye:
bigpanda 24th April 2005 04:46 PM
Did you look at AV400 by Holton
edl 24th April 2005 06:45 PM
lets bulid Quasi's great quasi-complementary design.
that gives 350W(rms) to 4ohm. of course with lower rails (and maybe a few modifications) the power will be less, so if 250-300W is enough, you can use 60-70V idle rails.
http://www.diyaudio.com/forums/showt...331&highlight=
on the last page of the thread you will find the attached schematic in "pdf".
there is pcb-drawing there, too.
it's recommended to read the whole thread!
(instead irfp450 you can use the cheaper irfp240 in the output)
ezis666 25th April 2005 11:51 AM
Yes, i have tested and this is good:cool:
quasi 26th April 2005 01:48 AM
Hi Rasvan
The amp suggested by edl and ezis666 has been running now for more than a month without any issues. It is very quite when idle and very clean under power.
Last week I took it to a friends house for it's first public audition.
We ran a NAD CD player and NAD receiver as the pre-amp into the power amp driving a set of IMF transmission line speakers (very nice speakers).
Everyone was impressed with the amp and another amp will be built by the host and his son as a project.
If you decide to build it, contact me if you want any advice.
Cheers
amplifierguru 26th April 2005 02:01 AM
Hi quasi.
Does your amp have a turn on thump? Have you tried to DC couple it to eliminate the electro's from the signal path?
Greg
quasi 26th April 2005 02:51 AM
Originally posted by amplifierguru
Hi quasi.
Greg
Well yes and no.
The amp boards themselves do when they are first turned on and the woofers do pop a bit.
The completed amp has speaker delay via the protection circuit and this comes in about 4 seconds after the amp is turned on so no thump is sent to the speaker.
You will note that I also a have a soft turn on cct for the powersupply and this lasts about 1.5 seconds. This means that the voltages for the amp modules rise slowly and a speaker delay is required to prevent any problems here.
Cheers
amplifierguru 26th April 2005 03:21 AM
Just wondering. I used to make PA amps similar to this topology in the 70's but with complementary feedback triples using MJ15003/4. There's probably a few still floating around there they were installed in a lot of clubs and discos.
They didn't us a relay output so I dethumped the turnon by using a long RC timeconstant feed to your T7 which simulated the slow charge-up of the primitive bootstrap which never thumped.
You don't mind having electro's in the signal path?
Have you tried cascoding the input stage/ FETs instead of the bipolars? dead easy with no circuit changes just drop in.
quasi 26th April 2005 03:35 AM
The final version of the amp does not use a cascode input stage but rather a current mirror. A FET input stage would work well as you sugested and would be a "drop in" provided the FETs were rated to at least 75v. In my amp I use a 1uf MKT style capacitor for the input.
Cheers
Coulomb 26th April 2005 03:49 AM
Check this thread.
http://www.diyaudio.com/forums/showt...threadid=54861
Copyright 1999-2017 diyAudio
