#31 |
Is it just me or does it look far too complicated for what it needs to do? It's not too diufficult to make an attenuator that has 2^N steps (N being the number of relay contacts), and has any dB per step value you want, using 2*N + 1 resistors, that also has constant output and input resistance regardless of the setting, and can be driven by a binary combination to address the attenuation needed, dirtectly?
#32 | |
OK, let's revive this post...
I would appreciate the circuit for the control system as well as the attenuator. Many thanks. |
#33 |
it seems a series type volume control.
how about to build a shunt type? but shunt type volume control needs twice of relay and resistor. i have a todo plan to build a shunt type volumen control using bit map control. anyone have interesting? |
#34 |
Create a reed switch controller using a flash ADC with any analog voltage sensing on the input... even an ordinary volume pot?
Lech |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 08:20 PM |
| Remote volume control for existing remote? | theAnonymous1 | Parts | 7 | 6th August 2007 09:22 AM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 12:12 PM |
| Remote Volume control? | filholder | Chip Amps | 22 | 12th April 2005 07:56 AM |
| Page generated in 0.08457 seconds (74.56% PHP - 25.44% MySQL) with 11 queries |
