Old 26th April 2005, 03:06 AM   #21
Account Disabled
Hi audio-gd,
Can you scale the R's down so Rout = 1K . 10 times lower and what would be Rin loading for previous stage. High Z is more noisy also a good reason for low Z.
Old 26th April 2005, 04:21 AM   #22
HFGuy is offline HFGuy  Canada
Thermal Noise (also called Johnson Noise)
en = sqrt{4kTRdelta(f)}
Reduce the bandwidth or Resistance
Old 26th April 2005, 06:12 AM   #23
Account Disabled
Very good, HF Guy!
that little k is Boltzmann's constant = 1.38 x 10to the power -23 juoles/deg kelvin. Not something I have instant recall of always.
I always remember it as 4nV/ sqrt Hz for a 1K resistor and proportional to sqrt R for scaling.
It helps being a physicist.
Old 26th April 2005, 02:43 PM   #24
Change the resistance can change the impedance, but a bit thick small will weightily load to forward stage, although it can lessen the noise and more.
Old 27th April 2005, 01:22 AM   #25
Account Disabled
Audio-gd
How weighty - 10K loading on CD or line amp is OK.
Old 27th April 2005, 01:37 AM   #26
Banned
what parasitic?
what is parasitic volume control?
all i see is a logarithmic attenuatorl
please enlighten me
Old 27th April 2005, 02:21 AM   #27
10K is ok, but if less than 10K, for example :1K, it's weightiness load to CD or some buffer.
Old 27th April 2005, 02:34 AM   #28
Account Disabled
Just to clarify, you can make it so it is -
10K load on preamp and 1K source to power amp, yes?
Old 27th April 2005, 01:50 PM   #29
No, I only can make as a manual volume controler
Old 28th April 2005, 03:26 PM   #30
Artmaster's Avatar
Send a message via ICQ to Artmaster Send a message via MSN to Artmaster
volume controler... what for?
could you change volume level in the concert hall?
I'm not think so.
I never do any volume control in my amplifier. I've set it up during instalation.
I have not problem about different room reaction by different sound precure
and I have clean fron panel as well
http://www.artmaydan.org.ua/hi-end/amp_s.jpg
http://www.artmaydan.org.ua/amp.html
Artmaster live in www.artmaydan.org.ua
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 09:22 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 12:12 PM
Remote Volume control? filholder Chip Amps 22 12th April 2005 07:56 AM
Page generated in 0.11315 seconds (73.82% PHP - 26.18% MySQL) with 11 queries
