How to make constant gain amplifier circuit
Old 21st April 2005, 05:20 PM   #1
aht is offline aht  Thailand
Account Disabled
Send a message via ICQ to aht Send a message via MSN to aht
Question How to make constant gain amplifier circuit
I want to design constant gain amplifier circuit from standard transistor amplifier and not use negative feedback.
This amplifier must be run in class-ab is it posible ?
Constant gain amplifier can explain so easy such as ... 20log Vo/Vi = 30dB at every input voltage & every frequency & every speaker.
Can it's use electronic circuit or digital circuit for control gain ?
notice : this constant gain amplifier circuit will be insert between output of amplifier & feedback input stage
Regard
AHT
Old 21st April 2005, 07:41 PM   #2
ilimzn is offline ilimzn  Croatia
It is practically impossible to build an amplifier of almost any kind without some sort of feedback - at the very least, local feedback. If you are asking for an amplifier run in class AB without global feedback, this is actually quite simple. There are several mentioned on this site.
Electonic gain control should be possible though it may get complicated.
Now why would you want to insert an amplifier between an output of another amplifier and it's feedback node is something I don't understand - the net result will be an amp with attenuation and not amplification (-30dB attenuation)?
Old 22nd April 2005, 12:37 AM   #3
bobo1on1 is offline bobo1on1  Netherlands
Another disadvantage is the distortion of the amplifying stage between output and feedback input also shows at the output of the amp.
Old 22nd April 2005, 03:50 AM   #4
Account Disabled
This circuit no need to insert between an output of another amplifier and it's feedback node. (that is my little idea )
After I serched data about "Constant Gain" I found "Linear Amplifier" for radio tranceiver. Do I use this circuit topolohy?
http://www.hindawi.com/journals/mpe/...X04402038.html
Regard
AHT
Old 22nd April 2005, 11:58 AM   #5
If you could describe what you are actually trying to do (and not how - we will get to that later) we may be able to help you better...
Old 22nd April 2005, 12:37 PM   #6
Mr Evil is offline Mr Evil  United Kingdom
Default Re: How to make constant gain amplifier circuit
Originally posted by aht
...at every input voltage...
By this I take it you mean high linearity, i.e. low distortion?
...& every frequency...
You can't have constant gain at every frequency. Frequency response can extend down to DC, but it can't extend up to infinity; there must be a limit somewhere. If you need extremely wide bandwidth then it will mean compromises in other areas, such as reduced linearity or gain.
...& every speaker.
Insensitivity to load, I take it this means. That's not too hard. Just keep the output impedance as low as possible and pay careful attention to stability.
You should note that all of these characteristics will be improved by using negative feedback.
https://mrevil.asvachin.eu/
Old 23rd April 2005, 04:30 AM   #7
Account Disabled
Talking Excute me
1.Every frequency = 20 - 20000Hz
2.Every input voltage = not more than 2.2V (will be satulated)
3.Every speaker = 4 & 8 Ohms impedance from really work
Sory for my bad English
Regard
AHT
Old 23rd April 2005, 03:59 PM   #8
bear is offline bear
expert in tautology
bear's Avatar
Ummm...
Are you trying to build a volume control, an amplifier or address a real world implementation of something you are studying like this:
"the stabilization problem of the class of continuous-time linear stochastic hybrid systems with Wiener process. The "H-inf"state feedback stabilization problem is treated."
(from the paper you mentioned).
This is the question you need to address before anyone has any idea what you are asking about. Ok?
FYI, if it pertains to the quote above, I have no clue at this point what the heck they are yammering about!
_-_-bear
PS. "Linear Amplifier" for "transciever" usually means an RF device and not suitable for audio frequencies regardless.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
How to make constant gain amplifier circuitHide this!Advertise here!
Hysteretic self-oscillating amplifier with constant switching frequency sovadk Class D 8 18th November 2006 11:44 AM
How do I bias up a constant current series filament circuit? sgerus Tubes / Valves 19 25th October 2006 12:13 AM
Constant Amplitude Phase Shift - CAPS Circuit mskeete Solid State 1 5th June 2005 04:38 AM
Constant Current Source Circuit mrfeedback Solid State 8 22nd April 2002 06:07 PM
