Schematic for A6000
http://www.schematicsunlimited.com/c/chevin/chevin-a6000-amplifier-service-manual
Chevin amplifiers User Manual
http://www.ctxd.com/items/chevin.pdf
George
George
I just checked most of the components on my A2000, and they seem to be ok, so im going to give it a try.
The ting is, the PCB with softstart and rectifier does not look good so im going to remove it and use a softstart module and a rectifier bridge. But im not familiar with this kind of PSU.
Does it really require that one of the mains AC wires are connected to 0v ?
Hello ,
you have schematic or a picture showing the parts for the chevin oscillator module (the circuit contained in the aluminum casing) mine is burnt so i cant distinquish which and where zener diodes are placed
thanks in advance
I realize these pics arent much help.. nice paint job... ut I can try some measurements if possible. I have a feeling the voltage is somewhere around 350v ? I have never messed around with SMPS before, so I know very little about them..
Is it possible to measure a zener without high voltage running trough it?
Thanks alot Chevin .. its a 20 year old unit. What does it matter if you release the schematic or even better, a service manual.
