okay
I build 2 channels 12/24 dB/Octave 3-Way Linkwitz-Riley Electronic Crossover, project 9 from ESP i made the PCB my self, both channels have own regulatet power supply, but i use the same trasformer for both channels. there is a problem whit noise tho. when i only connect one channel ist fine. no noise. but when i then connect the the input phono plug into the other channel i get noisy. its not 50 or 100hz. alot higher. its not very loud but to much. the same thing happens is a connect both channels in a stereo amp, if i use mono blocks there is no problem. can anyone tell me what i have done wrong here? Tnx, and sorry for my poor poor english hope you can read it. here is a pic |
#2 |
It seems like you have a problem with your Gnd-connections......
You may have caused a Gnd-loop.... Remember that all Gnd connections must be wired to a common Gnd-point at you power supply..... Have you remembered to fit the rca-plugs (phono-plugs) isolated from the cabinet, and each with its own wire to the central Gnd-point ???
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
but why do i not get any noise the i connect only 1 channel?
the rca-plugs is soldered directly to the pcb. can it be the groud wire to the transformer causing, this group loop. see pic |
#4 |
Hi again,
Because the second rca-plug makes the gnd-loop...... It's not easy to see the details on your picture..... If you want to, you can contact me directly on one of my emails; just add jd@ in front of one of my webs
#5 |
Did it Himself
Because the loop is only formed when you add the second channel.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
ACD you got mail
| Noise problem in active crossover | docaudio | Solid State | 4 | 9th June 2008 02:28 PM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Active Noise Cancellation | gcladis | Pass Labs | 4 | 27th June 2006 11:36 PM |
| Active Noise Cancellation | manse | Everything Else | 7 | 31st March 2003 04:57 PM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 01:29 AM |
| Page generated in 0.09327 seconds (74.39% PHP - 25.61% MySQL) with 11 queries |
