Old 19th April 2005, 05:20 PM   #1
javey is offline javey  United States
Question Mackie power amp distorting
Ch 1 works great,Ch 2 begins to distort immediately and gets worse by the minute to the point of total breakup. I have replaced all output transistors and drivers for this channel. I thought they were leaking while getting warmed up but this has not changed the symptons whatsoever. I cannot find any shorted diodes or open resistors. The power supply caps read within normal charge,but my tester doesn't have a leakage detecting feature. And i can't say for sure what they're doing while the amp is running.
What are the main causes of distortion in solid state amps,where it gets progressively worse?
The amps protection circuit does not come on and nothing is burning up smell wise. Its a 1400i if anyone is familiar with these things. They had a ribbon cable issue in the past,but they've all been replaced on mine. Like I said,right when you turn the unit on it mildly distorts with the ouput dial cranked and then gets worse and worse over the next thirty seconds. A minute or so later even if you turn the gain down its breaking up horribly. I also have gone over all connections and solder points without any change whatsoever.
Old 20th April 2005, 02:31 AM   #2
Is this thread too beginner for the forum? Any tips and advice would be greatly appreciated.
I just do basic solder work,but would love to learn more.
Old 20th April 2005, 03:45 AM   #3
Enzo is offline Enzo  United States
It is not too beginner, I think no one has any particular insight into this. Ther is nothing inherent to SS amps we can point to. I hate working on Makie stuff myself, and I make a living running a pro audio repair facility.
I would bet an op amp is cooking or maybe a cap in the signal path is leaky.
Ny the way, I am down in Lansing at 517-882-2544, and in the shop weekday evenings after 6:30PM. You can call.
Meridian MCD Distorting doarkface Digital Source 0 10th February 2009 07:47 PM
Distorting Accuphase E-302 reins Solid State 6 18th January 2007 07:48 AM
Distorting 5687 preamp circuit dsavitsk Tubes / Valves 13 14th June 2006 02:31 AM
Sub distorting - help please Simpleton Subwoofers 8 14th August 2005 06:56 AM
Gainclone distorting in the higher frequencies jaume Chip Amps 9 26th March 2004 07:07 AM
Page generated in 0.06846 seconds (70.12% PHP - 29.88% MySQL) with 10 queries
