HI all!,
I need some help on a few things. I posted about a yamaha m-50 I am working on. Well, I replaced the outputs. Reassembled the chassis and, it will not power on now. I never touched anything but the output board. The test on the triac shows 2.3Vac, but the spec is 5.5Vac. I'm lost!
The second thing is a Marantz 2330B. It belongs to a friend who's not so easy with his equipment. The power amp has given up in it. Anyone seen these before?
Last, I may be picking up a Carver M1.0T that powers on but has no output. What kind of things are common to fail in a Carver?
Any info will help! Thanks a bunch!
Roger
Roger
