Old 19th April 2005, 05:32 AM   #1
blu_line's Avatar
Default Stacking output transistors
I have been thinking about an direct drive ESL amplifier.
But th etrouble already starts at the output.
How can one stack multiple output drivers ?
mvg
Simon
Old 19th April 2005, 07:43 PM   #2
djk is offline djk
djk's Avatar
Use a pair of 811s and be done with it.
Old 19th April 2005, 10:15 PM   #3
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
not sure if you mean stacking output transistors, as the thread is named, driver transistors, probably both ?
For stacking devices you could read the Monaural 100 watt class A article of Norman Thagard, (Audio magazine, half of the 90s).
Looks like Sponge Bob has killed another thread.
Old 19th April 2005, 10:28 PM   #4
ilimzn is offline ilimzn  Croatia
What output voltages would you be looking for? 1400Vpp or even more is not a problem with MOSFETs, though it does take some creative thinking...
Old 20th April 2005, 01:05 AM   #5
anatech is offline anatech  Canada
anatech's Avatar
Try looking at horizontal output transistors for TV's. Just NPN that I know of.
-Chris
Old 20th April 2005, 08:24 AM   #6
blu_line's Avatar
@ilimzn
around 1500vpp, yes !
@djk
811s ? euhh please specify (tube/solid state)
@jacco
Do you have the article ?
grtz
Simon
Old 20th April 2005, 11:15 AM   #7
Well, you need to drive the ESL with differential voltages anyway, so you can make a fully differential MOSFET amplifier - single ended class A at that (you want to avoid referencing the signal to the + power rail if possible). A differential amp with an 800V power rail could swing >700V on each output, and twice that between outputs. You would need >800V MOSFETs but these are actually quite common. The best bet would be to look for fairly low current MOSFETs as these will have low input and reverse transfer capacitance. This is especially important as an ESL directly driven does not have a very large capacitance, and this is the only thing that limits the amps HF response. If that sort of output swing works for you, MOSFETs are a good bet. If not, you will have to go with tubes.
If you do use MOSFETs, the real problem is making current sources from the + rail to the MOSFET drains - the problem is supplying the required voltage reference. P channel MOSFETs capable of withstanding 800V or more are NOT common, so you end up with floating voltage references, which need to swing along with the output signal - the biggest problkem here being that various passive networks tend to consume lots of current and, you get capacitance from the said reference voltage sources to everything else.
A friend of mine that tried this approach back in 1992, and here is what he used:
Each leg of the differential output was a N-channel MOSFET current source that had a well insulated 9V battery as a reference voltage source for the Vgs of the MOSFET. The current source was the top of a MOSFET + BJT cascode, with the BJTs configured as a LTP. The LTP was balanced via a dual OP-amp DC servo (FET OPs and some very large resistive dividers!). This drove a 4" x 6" experimental ESL midtweeter cell with about 1.5mm interelectrode distance (i.e. standard PCB thickness) and a polarising voltage of about 8-12kV - it got incredibly loud! Transistors were BUZ80 if I recall right, +rail was 760V. In 1992 this was the only MOSFET one could find that could work for this application. Unfortunately, I completely lost contact with this guy... I wonder what the standing current was...
Old 20th April 2005, 06:42 PM   #8
djk is offline djk
djk's Avatar
Audio Amateur had a construction project for a direct coupled ES amplifier using a transmitting triode.
Back issues may be ordered from AudioXpress.com.
An 811 is a currently made $24 transmitting triode that has a cut-off of 2KV and is normally run about 1.2KV or so. I've seen NOS RCA 811s for as little as $10. A lot more rugged than any transistor, these would be my choice.
If you want to play with FETs I would use the 811 as a cascode to handle the power.
Supertex makes high current/high voltage depletion mode FETs in a TO220 case.
http://www.supertex.com/products/selector_guides/102
Old 20th April 2005, 06:56 PM   #9
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
[snip]
AX also carries a book by author Roger Sanders describing the direct drive amp & variations as well as ESL contruction. Should be on the AX website.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 20th April 2005, 07:07 PM   #10
SY's Avatar
For many ESL's, you'll arc them. The max plate voltage rating is too low for satisfactory volume, as I found out the hard way.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
re-stacking an output transformer mctavish Tubes / Valves 0 22nd February 2009 06:24 AM
output transistors pezza89 Vendor's Bazaar 0 2nd November 2007 10:14 PM
drive output transistors with an IC Jared Solid State 11 23rd July 2007 05:56 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 12:06 PM
Output Transistors weinstro Parts 1 9th May 2003 11:51 AM
Page generated in 0.10223 seconds (82.93% PHP - 17.07% MySQL) with 10 queries
