Stacking output transistors
Old 20th April 2005, 09:31 PM   #11
ilimzn is offline ilimzn  Croatia
Depends on what kind of ESL you are planning to drive. If it's a full range, 1.5kVpp will not be nearly enough. But for a stat working upwards of 300Hz or so, electrode distances and polarisation as well as drive voltage goes down drastically (voltages rise with the square of electrode distance).
Old 21st April 2005, 05:32 AM   #12
blu_line is offline blu_line
blu_line's Avatar
@janneman
Good to see you alive and kicking again !
grtz
Simon
Stacking output transistorsHide this!Advertise here!
re-stacking an output transformer mctavish Tubes / Valves 0 22nd February 2009 06:24 AM
output transistors pezza89 Vendor's Bazaar 0 2nd November 2007 10:14 PM
drive output transistors with an IC Jared Solid State 11 23rd July 2007 05:56 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 12:06 PM
Output Transistors weinstro Parts 1 9th May 2003 11:51 AM
