Neet to make a + 0 - 12dB software controllable line level amp.
Old 18th April 2005, 01:11 AM   #1
bans25 is offline bans25  United States
Default Neet to make a + 0 - 12dB software controllable line level amp.
HI all,
I am new to playing in the audio / video world so forgive me if I ask dumb questions! .
Currently interfacing to a TI AIC23 ( http://focus.ti.com/lit/ds/symlink/tlv320aic23b.pdf ) audio codec that has unbalanced consumer line level inputs and outputs.
What I need to do is make a PCB that will convert these 1Vrms I/O's to interface with (unbalanced) Professional line levels (+4dbu).
So I will need to PAD the input to the codec ( +4dbu Professional line level ----> -10dbv Consumer line level) right? 12db pad?
I am thinking of using the DS1808 for the attenuation.
Now I need to amplify the output of the codec (-10 dbv Consumer line level ----> +4dbu Professional line level) 12db amp.
Any ideas on whats good to use for a 12dB line level amp?
Here is the catch, I would like to be able to still also interface my AIC23 to consumer equipment or professional equipment and select the pad/amp via software control. So the DS1808 works out well for that, but I am having trouble figuring out what to use for a Software controllable 0-12dB amp!
Does anyone know of any ICs that may help me out to do this? maybe some digitally controlled pots?
I need to fit this circuitry on a 3" x 3" board to fit in the box.
Any suggestions are greatly appreciated
thanks
-Bill
Old 18th April 2005, 01:58 AM   #2
Im now thinking a simple OPA627 for the line level amp...
Whats a good way to be able to control the gain via SW?
Is it posible to be able to select from a gain of 1, or 4?
Will the op amp operate at a gain of 1? or is there always a gain greater that 1?
thanks
Old 18th April 2005, 02:40 AM   #3
paulb is offline paulb  Canada
A relay would be the simplest. Small double pole reed relay should do it. Have it switch in different resistor values to choose your gain.
Yes you can have an opamp with a gain of 1.
Old 18th April 2005, 09:32 AM   #4
Rambi is offline Rambi  Netherlands
Not all opamps are unity gain stable (OPA627 is). If you use an opamp other than the OPA627 don't forget to check the specs to see if it is unity gain stable!
Good luck,
Remco
Old 18th April 2005, 09:18 PM   #5
jaycee is offline jaycee  United Kingdom
WM1886 will allow you to control the gain of an opamp via SPI.. you could hook this up to a Microchip PIC which could be programmed as an SPI<->RS232 interface or whatever you need
Old 19th April 2005, 07:02 PM   #6
Probably you mean WM8816?
Other chip is MAS9116 which is similar (?), at least according to this page.
I haven't tried these personally. I did try PGA2310 + PIC as a volume control; but I wasn't impressed by the sound quality (dull, flat, and lifeless are words that come to mind).
Difference is that the PGA2310 has an opamp built in (so I might try a WM or MAS with a discrete opamp some day, to see/hear if that sounds better).
To be honest: People have reported good results with a PGA2310, so personal preferences possibly play a role here
(and the effects of using a breadboard for testing)
Remco
Old 19th April 2005, 08:09 PM   #7
Whoops, yes I meant the 8816.
Old 20th April 2005, 02:06 AM   #8
HHmm.. for the output gain, I think I could use the Head phone outputs (which have volume adjust) and then used a fixed gain opamp right?
Old 20th April 2005, 07:31 PM   #9
You're right.
That makes it much easier: simple resistor divider at the input and fixed gain opamp at the output.
I guess I should read the sheets first before commenting
Neet to make a + 0 - 12dB software controllable line level amp.Hide this!Advertise here!
Convert Line Level to Electric Guitar Level miallen Instruments and Amps 4 16th May 2010 02:22 PM
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 04:36 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 01:25 AM
Feasible to make a line-level 3rd-order infrasonic filter? noah katz Subwoofers 19 21st September 2005 07:35 PM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 05:13 PM
