need help with gallien krueger 800rb
im not getting any out put, everything lights up but no output.
im thinking its output transisters?????? any help :xeye: |
If it was the Output Stage then it probably would have blown the line fuse. They normally go short and cause an imbalance at the O/P. Can you obtain a schematic and post it here or email?
I may be able to steer you thru repairing it.... |
With two channels or output power, I would agree that output transistors is probably not it. Unless a channel has failed and took out the 60v supplies or their fuses.
Make sure the 60 volt rails are present. Make sure the +/-15VDC rails for the op amps in the power stages are present. Make syre the +/-15VDC rails are present in the preamp curcuits as well.. COnnect the effects send jack to the inout of another amp. If you can hear it there, then the preamp is at least partly working. Likewise, plug a guitar into the effects return.. That woukd check the power amp and later section of the preamp. Is there a signal on the Direct Out jack? Make sure the Biamp/Full Range switch is working - check the resistance at its contacts. |
i caint find a shcematic on this amp do you have one?
2 Attachment(s)
here are the schematics
2 Attachment(s)
and more
2 Attachment(s)
and this is the last one. sorry so many post but file was to big for just one
That means the power amp is working. That means the output transistors for that power amp are working. it means the problem is in the preamp or the effects loop jacks themselves.
how could it be in the effects loop jacks???
and thanx for all your help |
| All times are GMT. The time now is 08:46 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
