hey!
i need your opinion. i upgraded my sony ta-1010 vintage hi-end amp's original rca's to neutrik professional ones. also i wanna change the signal cable. so i have two cables to choose atm: 1) solid core bare copper conductor AWG24 with PE insulation 2) stranded (litz) silver-plated copper AWG24 with Teflon insulation which one you would reccommend? i know that teflon is way better than PE but its short distances (max 25cm) and solid core bare copper is better for signal i guess, does this teflon insulation outweigh this? waiting answers...thanks ron |
#2 |
Each will do fine, unless the stranded is shielded.
/Hugo |
#3 |
no, it's not shielded, the outer look is like this solid core cat5 conductor
both awg24 too. i think i choose this solid core bare copper, it might be better than this litz for this signa... |
| Wiring HT2 MTM | ZoZat | Multi-Way | 4 | 15th May 2009 09:17 PM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| Page generated in 0.07446 seconds (68.71% PHP - 31.29% MySQL) with 10 queries |
