I need a filter expert on this.
This is a fourth order 10 KHz lowpass filter made of a pair of 2nd-order sections. There is an upward departure from target at -80dB level. Is this due to excessed phase rotations in the opamps? Can this be cured with frequency compensation? If so, how do you apply this with S/K and MFB type of lowpass filters? If you can also help me with a link, it will be appreciated! Luke |
#2 |
Did it Himself
What filter topology are you using? My Sallen-Key filters work fine.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Sallen-key or multi-loop feedback design...they have the same problem . Same problem with OP275, OPa213x, and others. All departs from perfect LP4 transfer functions.
Is your a dual 2nd-order cascade? Tuned somewhere between 1 and 10KHz? Did you measure it down to -100 dB? I read something long time ago about this...don't remember where. Luk123 |
#4 |
It's due to finite op-amp bandwidth. Use an op-amp with a high GBP to minimize the problem.
https://mrevil.asvachin.eu/ |
#5 |
There has juwt been a nice article on the bob pease show about that
available on www.national.com it's due to the opamp bandwidth, but optimal component values can give better results
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#6 |
Hey Broccolo!
Do you remember the title of the article? Any cue available? Luke123 |
#7 |
on national's website, do a searh on "bob pease show"
I think you have to register an account to have access to it and it's not an article per say, it's a show
#8 |
Account Disabled
What chips are you using - as has been said, ones with higher GBW are the go!
OPA627 is best! But you can use lesser chips if the alignment is low Q i.e. Butterworth or Bessel, Chebyshev give steeper cutoff but require more GBW and give a distortion spike just below cutoff frequency. If it's for a quality audio use MFP will give lower distortion and best to use more sections of low Q depending on the application. Hope this helps. |
#9 |
Account Disabled
Some more...
A rule of thumb is for MFP sections GBW should be > 100xGAINxfn (natural for section) For Sallen-Key GBW should be > 100xGAINxQxQxQxfn so if Q is high it's very high. |
#10 |
Thanks for collaboration
When I started this thread, I just wanted to expose my problem in a very simple way. Bricolo pointed me out at the Bob Pease show link. (Thanks by the way.) But I have already seen it and this is what inspired me to write this thread actually. The picture is a screen capture from a Webench simulation. I did this because I don't have the original measurements of the specific problem. Exposing the thread this way was much more simple for me. Amplifier Guru : The two LPF2 in cascade had a F-Q values of 1300Hz/1.3 and 1500Hz/1.35. The tried Opamps were OP275 and OPA2134. I am aware of your law for needed bandwidth versus frequency/Q/gain and these opamps does not infringe this law. Anyway I remember having tried it with AD745 with the same results. I'm sure it have something to see with a custom frequency compensation for slowing down phase rotation in VHF. But how? Luke123 |
| Transformer expert needed. | nairod156 | Solid State | 4 | 13th January 2009 11:35 PM |
| 3-way crossover expert needed | andrew01 | Multi-Way | 28 | 9th November 2007 11:53 AM |
| Is Lowpass filter needed in 6ch amp? | Wynand | Chip Amps | 4 | 24th November 2005 04:34 PM |
| Help needed for active filter | k1jroth | Chip Amps | 0 | 23rd February 2005 03:14 PM |
| TL expert needed | MadMax | Multi-Way | 1 | 12th June 2003 03:48 AM |
| Page generated in 0.12753 seconds (71.21% PHP - 28.79% MySQL) with 11 queries |
