Technics SU-7700
Technics SU-7700
Old 14th April 2005, 06:27 AM   #11
rhymeswthorange is offline rhymeswthorange  United States
rhymeswthorange's Avatar
Have any suggestions as of brands to use? The caps in there actually look very similar to modern Xicon packaging... I wonder if they are original? 'Cause the power supply caps look nothing like them besides a common cylindrical shape. Can I use some plain old dirty Xicons, or should I opt for something a litte more refined like Elnas? Does it really matter in this application?
Old 14th April 2005, 02:43 PM   #12
K-amps is offline K-amps  United States
K-amps's Avatar
If I had Fe207's.... I get a nice reliable amp and not muck with the Technics, one slip and you will blow those nice drivers..... Just my humble opinion.....
Old 14th April 2005, 04:30 PM   #13
so what kind of amp would you recommend? Remember that I am a humble college student and cannot spend a fortune.
Old 14th April 2005, 09:07 PM   #14
K-amps's Avatar
Whatever your budget allows..... whatever sounds good to your ears... just not a half broken amp.
Old 14th April 2005, 09:40 PM   #15
anatech is offline anatech  Canada
anatech's Avatar
Technics SU-7700
Hi rhymeswthorange,
Use whatever new caps are in stock. They will be better than the original ones easy.
-Chris
Old 15th April 2005, 01:23 AM   #16
Nichon PW series OK? Low impedance... but says well suited for switched power supplies. I think I'm going to replace all the electrolytic caps in my amps using as many panasonic FC series as I can and filling the leftover values up with the Nichion PW's (FC's don't have very small capacitances with low voltages). Mayeb this question is a little absurd, but I really don't want anything damaged or sound worse... it sounds very nice now and putting aside the left channel being weak, this amp is awesome.
Old 15th April 2005, 01:29 AM   #17
anatech's Avatar
Technics SU-7700
Hi rhymeswthorange,
They should be fine. Asking about brands of caps is like asking what wine is the best. Dangerous question at the best of times.
Newly manufactured caps are better than those made a while ago. Manufacturing processes are better. Except of course the terrible caps that went into many motherboards and some car decks.
-Chris
Old 15th April 2005, 02:40 AM   #18
Oh, one thing I just noticed - I can hear a radio broacast out of my right speaker (strong side) and it's silent on the left. Problem? Indication?
Old 15th April 2005, 11:49 PM   #19
anatech's Avatar
Technics SU-7700
Change the caps first and report back. This may resolve other funny problems, or at lest make the clues more consistant.
-Chris
Technics SU-7700Hide this!Advertise here!
Sansui AU 7700 yeoldestereo Solid State 2 13th December 2007 01:20 AM
Technics SU-7700 Right Channel Issues Hydrogelic Solid State 3 31st May 2006 05:37 PM
Need any info for Sharp System-7700 ZuMbAiU Solid State 1 25th March 2006 10:47 AM
Help w? DVPS-7700 Downconverted output ljordan Digital Source 0 9th December 2003 04:31 PM
Master clock freq for Sony 7700? Smiffy Digital Source 2 5th December 2003 12:58 PM
